05-21-2004, 10:33 AM | #1 |
Stupid Question!
How do you get the ignition switch out of the dash?
"SicStee8" Chevy SWB Fleetside, in progress...500 HP 383 w/TriPower, 700r4, 3.73's, Lowered, Shaved Driprail/sidemarkers/handles/ant, Gonna rock!! '96 Chevy Tahoe 4X4 '84 Chevy C/K10 4X4 (FOR SALE) |
05-21-2004, 10:37 AM | #2 |
68 camtruck
Ignition swich
There should be a tiny hole in the outer cylinder. Use a stiff wire or maybe a paper clip might fit and turn the ignition switch as you push in.
It has been a while since i have removed one. But that is the way I remember it. Thanks Charlie
71 GMC Jimmy 4X4 68 Huger Orange Camaro 454 with TH400 :gmc: |
05-21-2004, 09:33 PM | #3 |
Born Psycho
put it in accessory position, paper clip in small hole, depress spring loaded pin, twist and pull out with key.unscrew the bezel and its done.
if you don't have a key, unscrew bezel as far as possible and use a BFH and a punch to knock it out.
jerry moss 72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD 69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies. 73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog. 77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW BRENTWOOD,CALIFORNIA |
05-22-2004, 12:30 AM | #4 |
Hey Jerry what does the "F" stand for in BFH? (friendly,fast ,Ford, foolish, etc.)
P.S. thanks again.
56 Chevy Bel-Air 2dr. HT (purchased new) 71 Chevy Cheyenne SWB PU (502HO) 65 GMC short bed step--work in progress and my gofer |
05-22-2004, 01:25 AM | #5 |
its all about the +6 inches
The 67 won't have the acc position, insert the paper clip and with the key, turn it counter clockwise. You migh have to wiggle and jiggle it a bit, but it should start to turn. Kinda pulling on the key helps a bit too sometimes.
05-22-2004, 11:47 AM | #6 |
if i remember right my old 67 had acc
'67 c10 350/th350 |
05-22-2004, 05:30 PM | #7 |
bfh = big f'in hammer i think
70 longbed 496/th400/Ford 9" |
05-22-2004, 07:46 PM | #8 |
my 67 has NO acc. position
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications click the clicky to join the site.... http://67-72chevytrucks.com/vboard/payments.php 67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44 Anderson,CA |
05-23-2004, 12:56 AM | #9 |
I have only messed with a few 67/68 trucks, but none of them had the counter clockwise ACC position. Only clockwise IGN and CRANK positions.
