Old 05-21-2004, 10:49 AM   #1
ShortBedChevy
Pic or good diagram of fireing sequence on 350?
What is the fireing (sp?) sequence on a 350? Someone messed the spark plug wires up and i need to get them straightened out.. i have a chiltons manual, but its only for 73-79 trucks.. and doesnt have a good diagram anyways... help? i believe its electronic ignition... its a stock distributer...
Chris
www.70chargerrt500.150m.com
ShortBedChevy is offline   Reply With Quote
Old 05-21-2004, 11:09 AM   #2
beaterC10
The firing order is the same for all small block Chevys. The cylinders on the driver side are odd, #1 is at the front. Passenger side are even, #2 is at the front.
If it is a factory intake manifold the firing order is probably cast on the intake surface in front of the carb.
Find or establish the #1 position on the dizzy cap and move around the cap in a clockwise direction connecting wires from the dizzy to the cylinders in firing order.
beaterC10 is offline   Reply With Quote
Old 05-21-2004, 11:24 AM   #3
swervin ervin
You get what you pay for
swervin ervin's Avatar
Here you go.
Mike
1985 Chevy C-10
swervin ervin is offline   Reply With Quote
Old 05-21-2004, 12:03 PM   #4
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
Except for the LS1.. 1-8-7-2-6-5-4-3
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 05-21-2004, 12:28 PM   #5
beaterC10
I thought about it after posting my reply. I knew someone would would get me on something.
Old 05-21-2004, 11:42 PM   #6
NeCrOmAnCeR
NeCrOmAnCeR's Avatar
Keep in mind that if the dizzy has been removed/replaced in the past, #1 may not be in that location. But that can be checked easily.
NeCrOmAnCeR is offline   Reply With Quote
Old 05-24-2004, 10:08 AM   #7
ShortBedChevy
thanks a lot
Chris
