Old 05-21-2004, 03:03 PM   #1
dubie
dubie's Avatar
nedd help with valves
I posted this over at the engine board as well
I know this has been discussed here before but my search came up with nothing. Can anyone lend a helping hand as to how to set the valves on my heads?
With any luck I will be starting this engine over the weekend, so I could use some help
My name's Tim and I'm a truckaholic
My 56 Chevy shop truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=562795
dubie is offline   Reply With Quote
Old 05-21-2004, 03:59 PM   #2
gr8scott51
gr8scott51's Avatar
Tim, have you already installed your intake? Seems like the last picture I saw, it was. If not, twirl the push rod while tightening the adjuster until snug, then another half turn. If you can't spin your push rods, just bring up snug plus a quarter turn. Either way, you'll probably want to reset them with the engine running (can be messy). If you have access to a diagnostics machine after you get it running, you'll find out how close you are. I always tend to overtighten mine and have to relax them during final tuning. Good luck, pretty exciting, huh?
Silence is golden, duct tape is silver. - Scott
gr8scott51 is offline   Reply With Quote
Old 05-21-2004, 04:29 PM   #3
dubie
dubie's Avatar
yeah, it is exciting!!! My intake is bolted back on but not torqued yet. I removed it to my pushrods a while back and then started focussing on the paint . It's gonna be nice to have this thing running because I'm getting really sick of pushing it in and out of the shop
Old 05-21-2004, 04:40 PM   #4
cableguy0
dont twirl the pushrods move them up and down even if you cant spin them that doesnt mean they are too tight. the best most accurate valve adjustment is to set the motor at tdc then turn it by hand when the lifter on the intake side starts to move up adjust the exhaust. when the lifter on the exhaust starts to open adjust the intake. just move the pushrod up and down and when it wont move up and down anymore go another 1/4 to 1/2 turn and your done
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 05-21-2004, 04:51 PM   #5
jhow66
jhow66's Avatar
adjusting valves
Try this :http://www.sallee-chevrolet.com/Cran...tallation.html
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 05-21-2004, 05:34 PM   #6
Bowtie67
Bowtie67's Avatar
The best and easiest way I have found to adjust valves is first put a jumper wire to the starter that will crank the motor, Next is to pick a side, make sure all pushrods are in the motor and all slack is taken up to the point that you just start to feel resistance on pushrod turning it. On the side you are on start at front or back doesn't matter, Bump the starter button till you feel the first one go down and start seeing it's partner start to go up, This lifter is now at it's lowest point, adjust the nut till the pushrod starts to have resistance and then turn one half turn and move on to the next valve.
Doing it this way I have never had to go back and readjust valves and I dont to have to jump all over the block figuring which one I am supposed to do next.
1967 C10 - SWBSS Pro Street 427sbc, 700R4 & 4.10 Gears
1948 Chevy FleetMaster Coupe, LS1, (almost done)
1950 Chevy StyleLine Coupe 250/6 3x2 Dueces
2009 Toyota Tundra
1996 Harley RoadKing
"I maybe getting old, but I can still burn rubber with the best of them"
Bowtie67 is offline   Reply With Quote
Old 05-21-2004, 11:03 PM   #7
71Rat
ran out of money
71Rat's Avatar
how would you go about adjusting them with the intake on and the engine able to run? i have mine set so the truck runs 1/2 way decent but i think a little valve adjustment might help out. I have the clips to go over the pushrod so i dont get shot with oil, but then how do i go about adjusting them?
SORRY TO HIJACK THE THREAD! but i was wondering the same thing and was about to atempt to do it tomarrow, by the way one guy told me to... just looking for backup help.
Again i am sorry to hijack the thread, but i would like to know also
Rat
Modify everything, leave nothing alone!~
71Rat is offline   Reply With Quote
Old 05-21-2004, 11:43 PM   #8
aesj2
Here is the correct way the set your valves. By hand set the engine to fire #1 cyl ( TDC ). Loosen the rocker nut till the push rod can be spun then tighten the rocker nut just to the point that the push rod has drag as is it spun. Do this for #1 I-E #3-E #5-I #7-I #2-I #4-E #8-E Then set the engine to fire #6 cyl ( TDC ) and set #3-I #5-E #7-E #2-E #4-I #6 I-E #8-I
Then all rocker nuts get 1 turn down. Good Luck
aesj2 is offline   Reply With Quote
Old 05-22-2004, 12:45 AM   #9
67shortie
Green club
67shortie's Avatar
I run solids in the 427, I have always used the intake opening/exhaust closing method and have never had a problem.
IO/EC=when the intake lobe is lifing the intake valve, adjust the exhaust valve. When the exhaust valve is closing, adjust the intake valve. Just take up all of the 'slack' in the lifter, (SLIGHT resistance on the twising method on the pushrod) and go another 1/2 turn for a proper adjustment on a hyd lifter. Works every time.
71 short/fleet ECE 4/6 drop, LQ4/700r4/3.42 gears
70 SS396 Chevelle 427/200-4R/3.73posi
61 Lincoln Continental, black on black
Son you are going to drive me to drinkin if you don't stop drivin that hot rod lincoln
67shortie is offline   Reply With Quote
Old 05-22-2004, 09:06 PM   #10
hanssolo
hanssolo's Avatar
With hydraulics, soak lifters in oil first and adjust once. I've seen many guys keep adjusting them down. All they are doing is squeezing the oil out and overtightening them.
69 C10 longbed: 357c.i. /TH400/3.73s/AC/ beige primer/saving $ for paint
______________________________
hanssolo is offline   Reply With Quote
Old 05-23-2004, 09:17 AM   #11
Bowtie67
Bowtie67's Avatar
Rat
You don't need the engine to run to adjust valves, unless of course you have solids and they require valves settings hot and it still doesnt require it be running. If you do one valve at a time you should have no need of having to pull covers off again unless their is another issue. It is always a good idea to presoak valves in oil but not an absolute neccesity.
2009 Toyota Tundra
