05-21-2004, 03:43 PM | #1 |
Garage Queen Material
brake caliper problem!
okay, my brakes were sucking so i decided to buy some new pads.
well, i get the old ones off and when the new pads are on, the caliper wont go on over the rotor. its as if the "cup" that pushes out when you hit the brakes is sticking out to far. how can i push it back in so it will let me put the calipers back on? |
05-21-2004, 03:52 PM | #2 |
You get what you pay for
With a big C clamp.
Mike 1985 Chevy C-10 |
05-21-2004, 03:53 PM | #3 |
Happy to be here
Yeah that going to happen. The caliper will expand while it's off of the rotor. Do you have a large C clamp? If you do then that will compress it. If not a large pair of channel locks will work too.
Next time find a scrap of wood or something to wedge in there while you work. I have seen the suspension shops crimp the rubber line with small vise grips while they work, but I don't recommend it....
05-21-2004, 03:54 PM | #4 | |
Happy to be here
05-21-2004, 06:24 PM | #5 |
ROCKET POWER!
Ocbaud, do yourself a favor. Next time you're replacing brake pads, take a prybar, wedge it between the rotor and old pad and pry the caliper piston inwards before you take the caliper off. That way the caliper is a lot easier to take off, and if you're careful you can push the piston in all the way and won't need to use a c-clamp to push it in. I do it every time i take the caliper off, doesn't matter if i'm replacing pads or not.
What did i do last nite? I had a wonderful time, That's what they tell me What did i do last nite? 1979 C-10 shortfleet: Olds 350, Th400, 12 bolt Current project: 1969 Olds 455 W-30, needing a rebuild |
05-22-2004, 03:06 AM | #6 |
Right turn Clyde
Take it easy and slow compressing the piston back down the bore. It will find a weak spot if you go to fast.
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73 1992 Camaro RS 305 TBI |
05-22-2004, 06:17 AM | #7 |
Don't forget to take the cover off of your fluid reservoir (sp?) and watch for overflow.
Chris '92 ext. cab s/b 4.3L "Sparky" '04 crew cab 2500 4x4 6.0L |
05-22-2004, 07:09 AM | #8 | |
it goes a lot quicker if its running. i bought a nice vice grip with a c-clamp on the end of it last night |
