Old 05-21-2004, 06:10 PM   #1
JayDubBlazer
go cyclones
JayDubBlazer's Avatar
Brakes locked up
I just bleed my brakes and backed it uabout 30 ft. I pressed the brakes and then they locked up. I believe it to be the front discs. Any help would be apprecieated.
Wes
PROJECT OLE GREEN
1972 Blazer 4X4 350/700R4
2017 Silverado LT
JayDubBlazer is offline   Reply With Quote
Old 05-21-2004, 06:44 PM   #2
jku72
I'm only guessing, but I'd say that there is a problem with the fluid return to the master. There are several reasons for this, and for a more accurate diagnosis, it would be good to know why the brakes were bled. New parts? Which ones?
Any way, the two reasons for this that i can think of off the top of my head are:
1. Brake pedal/ rod out of adjustment. in other words, the brake piston in the master cylinder is not being returned to its normal position. This means the return ports are not getting uncovered, so the brakes will be stuck on.
2. Dirt clogging the return port, this to me would on ly be likely if an old master was used, or the brake system had been empty for a while, so rust could form.
3. Okay, I just thought of a number 3, perhaps, if you have power brakes, the vacuum diaphram check valve might not work so well, this is usually indicated by the pedal staying dowwn.
4. Oops, they keep coming. If there was a stuck caliper this could do it.
5. Forget counting. If its in the rear brakes, and you had it disassembled, the brake adjuster could be in backwards, and any sort of forward motion is going to cause the brakes to over tighten. This happened to me once. It was very difficult to remove the brake drum because my brakes were so over adjusted.
Like I said, more info would make a diagnosis easier.
jku Cornville, Maine
68 C10 burb
42 Willys MB
46 Dodge WF-32 1.5 ton
53 & 56 Olds'
60 Cadillac
22 Dodge Brothers
jku72 is offline   Reply With Quote
Old 05-21-2004, 07:36 PM   #3
JayDubBlazer
go cyclones
it let go. But I relplaced the rear shoes and turned the drums. It was the front calipers that were locked up. I let it sit for a while and my father pushed it and it rolled. I don't know what happened. It is a newer master and the front pads were replaced last year.
Wes
PROJECT OLE GREEN
2017 Silverado LT
Old 05-21-2004, 11:38 PM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Get the fronts to lock up again (I'm asuming they remained locked up after you took your foot off the pedal?) Remove the wheel and loosen the bleeder. If the caliper releases it's grip, then your problem is not the caliper...some where in the rubber line, hard line, or master cylinder.
If it repains locked up, it's time of a caliper.
