05-21-2004, 11:56 PM | #1 |
OL BLUU
Pulling to the right when braking?
Hey guys I am a newbe to the site..... I have to say that this place Rocks!
My ride has been pulling to the right HARD... I replaced the both rotors & pads today. The thing is still pulling to the right, it's not a constant pull.. probably 50% of the time when I brake. Anyways the only thing I believe I have left is the calipers? I was wondering which one should I replace the left or the right.... my guess would be the right!?!? Or just do both...... ? My tires and wheels are newer, I don't think this would be the problem either. Thanks in advance for your input, Anthony |
05-22-2004, 12:07 AM | #2 |
if you are going to replace rotors do both. make sure you both sides are bled properly and also make sure you dont have a crimp in the lines.
05-22-2004, 12:32 AM | #3 |
You get what you pay for
Replace the calipers and brake hoses. Rebuilt calipers are cheap enough. It's a good possibility you have the hose on the drivers side collapsing or clogged. When this happens, it shuts off the brake fluid to this side and the passenger side is the only one working.
Oh, and welcome to the board. Where's the pics of your truck. It's mandatory for newbies to post pics. We love pics.
Mike 1985 Chevy C-10 |
05-22-2004, 12:35 AM | #4 |
Check the back brakes as well. A hung adjuster can cause issues like this. I recently had this problem on my 3/4 ton burb It showed upo bad while having ina 2k trailer behind the truck and making some hard stops. wasnt very noticable with the truck unloaded.
Grim-Reaper 70 Pontiac LeMans Sport Convertible, worlds longest resto in progress Looking for 71-72 2wd Blazer or Jimmy Project |
05-22-2004, 01:20 AM | #5 | |
OL BLUU
05-22-2004, 11:04 PM | #6 |
CHENGE BOTH RUBBER BRAKE HOSE'S
05-23-2004, 10:07 AM | #7 | |
Robert Current: 1986 SWB Silverado 4.3 / TH400 Past: 1985 SWB Silverado 305 / TH350 - sold 1995 1987 1/2 ton Silverado - FI 350 / 700R4 sold 2007 |
05-23-2004, 04:51 PM | #8 | |
OL BLUU
Thanks again for everyone's input..... I'll be tearing back into it in a couple more days, I'll let you know what I find out. |
05-25-2004, 02:16 AM | #9 |
if it's pulling to the right, the left caliper could be seized...
05-25-2004, 05:40 AM | #10 |
I got the same problem on "Ye Old Reliable" , it always pulled to the right , when it blocked once and for good : the right caliper was toast !
I bought 2 rebuilt calipers and new front brake pads from "Car-Quest" , for about 183€ ( almost 200 US$ ) it was solved... the Baron
1982 Suburban 2WD , 260ci Olds engine,TH400 , will get a 1979 front clip , might be ready in ... 2016 1985 Chevy Van ( 305/350 ) , "Kellogg" equipped , my actual D.D. 1960 Girl Friend , frame still good , body has some dents |
05-25-2004, 09:54 AM | #11 |
I had a similar problem last year. It would pull one way, then straight, then the other way when applying and releasing the brakes. New calipers and hoses did the trick. Memory is a bit fuzzy, but I think the rebuilt NAPA calipers were $15 each and the hoses about $30 a piece...
Good luck!
Semper Paratus |
05-25-2004, 05:26 PM | #12 |
Ultimate Diesel Dude
Like has been said, it's probably your hoses. Mine did the same thing, and it turned out to be the rubber hoses. They look fine from the outside, but the inside diameter had shrunk up on one of them, causing a restriction in the system.
Calipers are so cheap, you should probably replace both the calipers and the hoses.
Project truck: '81 C/20 converted to 6.2L TURBO DIESEL bored .040", gear drive, 6.5L injectors/pump, custom pistons, custom 4" exhaust, 700R4, 4.10's Daily Driver: '95 K1500 Tahoe, 6.5L TURBO DIESEL, NP241, 4L80E, 3.42's |
05-25-2004, 05:29 PM | #13 |
Parts and more parts
Go with the hoses and do the changeout. This is a mojor problem with these Chevy trucks. At one time or another we have all seen it.
