Old 05-22-2004, 09:09 AM   #1
jay6891
Car Knocker
jay6891's Avatar
urban myth or true?
Seeing how gas prices are way up and our truck are not known for thier gas milage, I thought I would bring this up. Yesterday when I was fueling up super unleaded @2.19 a gal, a guy walks up and tells me that if I would put a handfull of moth balls in my tank when I fuel, I could run lower octane and save 20 cents/gal. He said that when they melt in your tank they raise the octane level. That is what he does in his truck and race car. Man, I haven't heard this since I was a kid. Is it a myth or is it true? Needless to say, I have not done it, and when he drove off, by the sound of it, he will be walking soon.
68 c-10,91 sportside bed,350 .030 over,4 bolt,10-1 comp,2.05 intake/1.94 exhaust,1.6 Harland Sharp roller rockers,edelbrock rpm cam and intake w/750 carb, 700r4, 3.73 gears,Jacabbs Electronic Igntion w/Accel HEI distributer and super coil. ZR-1 roll pan, filled tailights. Blazer tank. Hidden hitch. 2 1/2" Flowmaster 40's. Parts bought but not installed>> ford 9" posi with disc. CCP front and rear lowering kit 4/5. Cab corners,foor boards,rockers, cab braces, Phatom grill, Painless wiring kit.
jay6891 is offline   Reply With Quote
Old 05-22-2004, 10:37 AM   #2
toddtheodd
The oddest Todd around
toddtheodd's Avatar
I don't know about raising the octane, but I do know that your car will move with moth balls in the tank. But then again, the moth balls will cause the engine to run so hot that the pistons will start to melt. put too many in and you'll actually have holes in the pistons. I've done like 2 or 3 moth balls before in my 81 buick. She ran like a raped ape like that. My friend saw what it did and put a handfull in his tank. A few days later he was looking at crate motors at the dealership to replace his ruined one.
toddtheodd is offline   Reply With Quote
Old 05-22-2004, 10:52 AM   #3
SCOTI
SCOTI's Avatar
19gal tank x $.20 savings per gallon of gas @ fill up time is $3.80. Is that worth destroying your motor?
If you ran the tank completely empty & had a formula to precisely measure out moth balls to gal/gas ratio, you possibly wouldn't damage anything. If you don't get a good ratio . . .... all it takes is once.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 05-22-2004, 11:11 AM   #4
grayw0lf
Mothballs have a very high nitrogen content. When they dissolve, the nitrogen dissipates into the gas. Its kinda like a backwoods nitrous.
Definately not good for the engine. Now, if you have a new engine on the way & want to send your old block out w/ a bang... put in a box of mothballs & you could have one Hell of a last ride!
85' CUCV M1009!!! The newest addition!
6.2diesel, Th400, NP208, & only 36k miles!
70' C-10 LWB Fleetside - Looking good these days!
05' Dodge Neon
88' Winner Escape Sport 1750 - 4.3v6
94' Seadoo SP
84' Honda TRX200, bare nekkid. Just a frame & tires.
Always looking for another project or any good deal!
grayw0lf is offline   Reply With Quote
Old 05-22-2004, 02:09 PM   #5
68 Suburban
68 Suburban's Avatar
From what I have heard, mothballs will raise the octane level, but im not sure it is that good for your fuel system.
Just sitting here contemplating contemplation.
68 Suburban is offline   Reply With Quote
Old 05-22-2004, 02:10 PM   #6
68 Suburban
http://www.freerepublic.com/focus/f-.../posts?page=11
You must, however, make sure you use the right kind of moth balls. Nitta says do no use moth balls made from something called paradichlorobenzene. Instead use what are commonly referred to as old moth balls. The active ingredient in them is naphthalene. By adding moth balls with naphthalene, Nitta says you'll not only get more miles per gallon, but added power too.
Old 05-22-2004, 04:29 PM   #7
Martin64
Martin64's Avatar
I think some anti-Pick-Up/SUV activist is yanking your chain and trying to get you to blow your engine up. Yes, moth balls will cause your engine to "melt down". We use to do it as kids to old motorcycles that we were getting ready to junk. They'd run like a bat out of he77 for a while.....
Martin Gibson
USAF Retired
1964(-ish) C10
Martin64 is offline   Reply With Quote
Old 05-22-2004, 07:20 PM   #8
tom hand
CCRider
tom hand's Avatar
Oh man, I shoulda read the whole article before I stuffed all those urinal cakes into my gas tank. . .
....lol.....I going to buy some moth balls and blow something up
72 GMC Sierra SWB almost finished---- 84 Softail
Olive Branch MS
tom hand is offline   Reply With Quote
Old 05-22-2004, 10:29 PM   #9
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
It is an old hot rodders trick, but everyone here is right, it'll blow your motor up.
Old 05-22-2004, 11:44 PM   #10
dion
72 Cheyenne
dion's Avatar
I heard that the old napathane moth ball weren't available anymore, I've looked around for them but have never seen them in any store. Do they still make them?
Burnout
Idle
1972Cheyenne
1966/67Stouts
dion is offline   Reply With Quote
Old 05-23-2004, 08:14 AM   #11
jay6891
Car Knocker
jay6891's Avatar
No, I'm not gonna do it. I can tear my stuff up easily enough without dumping something in the tank. Like I said earlier, I believe that by listening to his truck when he left, he'll be walking soon. Just wanted to know if anybody else had heard of this before.
Old 05-23-2004, 10:05 AM   #12
68 Suburban
If anyone is consider trying this, I suggest they put these in a bucket of gas first and make sure the disolve, before they shove them in their gas tank
Old 05-23-2004, 12:44 PM   #13
Baradium
Binder Rep
Baradium's Avatar
There are two types of moth balls. One will raise the octane level. The other will blow the engine up. The one that raises the octane won't hurt anything, but you only need like one for a full tank of gas.
Raising octane would be easier on your engine if you are easy of the happy pedal... means that the fuel burns cooler etc. Lower octane burns faster and hotter.
Baradium is offline   Reply With Quote
Old 05-23-2004, 02:53 PM   #14
slam33
slam33's Avatar
$2.19 for Super, try $2.70 out here in So Cal.
71 LWB 350/350still working on it but it's going tp be sweet. www.geocities.com/stevemau/slam33page.html
" TARGET=_blank>http://www.geocities.com/stevemau/slam33page.html?1004806705410
</A>
slam33 is offline   Reply With Quote
Old 05-23-2004, 03:26 PM   #15
Longhorn Man
Slam, how much tax are you paying a gallon? I'll bet your state is screwing you at the pump in addidtion to everywhere else you get/spend money.
Old 05-23-2004, 07:37 PM   #16
Jeepster376
Jeepster376's Avatar
Originally Posted by 68 Suburban
This may be key as to why this used to work, and no longer is done. With modern standard 87 to 93 gasolines, there'd be no benefit.
In the 1920s, typical gasoline octane ratings were 40-60 [11], and during the 1930s and 40s, the ratings increased by approximately 20 units as alkyl leads and improved refining processes became widespread [12].
Naphthalene has a blending motor octane number of 90 [52], so the addition of a significant amount of mothballs could increase the octane, and they were soluble in gasoline. The amount usually required to appreciably increase the octane also had some adverse effects. The most obvious was due to the high melting point ( 80C ), when the fuel evaporated the naphthalene would precipitate out, blocking jets and filters. With modern gasolines, naphthalene is more likely to reduce the octane rating, and the amount required for low octane fuels will also create operational and emissions problems.
72 Cheyenne Super 4x4 SWB
Jeepster376 is offline   Reply With Quote
