Old 05-22-2004, 01:43 PM   #1
ira ashley
Need help on cheyenne super
1-Need to know how to wire up cargo light & inside light.
The cargo light has a white & orange wire.
The orange wire goes to the on & off switch, were does the white wire go?
The inside light has a orange & white wire that plugs under the dash, does the cargo light hook to the inside light?
2-need pictures fo exactly wh ere the super emblem goes under the cheyenne on the fender need measurements also......
thanks Ira
ira ashley is offline   Reply With Quote
Old 05-22-2004, 02:57 PM   #2
super72bb
Ira here you go for the "SUPER" Emblem.
Gm set it up to have the "SUPER" directly below the CHEYENNE on both sides.
Acording to the Factory assembly manual this is correct for both sides. In other words you want to avoid having the Super under the "10"
Correct is:
[Cheyenne 10]
[ Super]XXXX
Incorrect is:
[Cheyenne 10]
XXXX[ Super]
The X's are just to show the space under the Cheyenne emblem. I hope that makes sense.
1972 CHEYENNE SUPER SWB BLACK. 402 BB, TH400, AIR, TILT, TACH, BUCKETS, CRUISE, AM/FM, 8 TRACK.
My build thread:
http://67-72chevytrucks.com/vboard/s...=1#post7120181
super72bb is offline   Reply With Quote
