Old 05-22-2004, 01:57 PM   #1
Wreck
Autometer gauge help
Its been awhile since I have been here and I am ready to update my gauges in my 72 super. I swear there was a whole thread on this subject with pics of peoples instrument clusters and all the info on it. I have tried the search and have not found the info I need. What I need is to know the sizes for the guages, particularly the small one (oil press, temp and volts). Thanks in advance for the help.
Wreck is offline   Reply With Quote
Old 05-22-2004, 03:56 PM   #2
greasemonkey
greasemonkey's Avatar
5" for the big ones, 3 3/4" for the middle one, and 2 5/8" for the small ones. The catalogs will say the middle one is 3 3/8", but on the guage box itself it is 3 3/4".
1942 Master Deluxe
1969 C/10
1985 Blazer CUCV
1987 Jimmy
2004 Tahoe
2005 Silverado 1500
2005 Silverado 3500
greasemonkey is offline   Reply With Quote
Old 05-22-2004, 04:55 PM   #3
toddtheodd
The oddest Todd around
toddtheodd's Avatar
do you have to remove the printed circuit board for those to work? What about the turn signals and bright indicator? I am also interested in switching mine up. I know I will keep an oil pressure and water temp gauges. But I can't decide on the other 2. I think I need the volts one for my altenator. What about a vacuum guage? I don't really know what a vacuum guage would tell me though, I just seen one advertised as a "stock replacement" for that one on the right next to the column.
toddtheodd is offline   Reply With Quote
Old 05-22-2004, 06:35 PM   #4
RON WOODGEARD
Resident Young Old Dude !
The Speedometer and Tachometer ar 5" in dash units. The 4 gauges in the bottom are 2-5/8" and the gauge in the center between the tach, and speedo is a 3-3/8"
The 3-3/8" one is discontinued from Autometer, The ones on the shelves are all there is.. Those are Phantoms. (White faced) they have no blackfaced 3-3/8" left...
I'm doing the same thing right now, only putting the gauges behind the bezel like this.
Yes you will have to remove the metal from the area behind the gauges in either case,
I need a Black faced 3-3/8' gauge,
RON WOODGEARD is offline   Reply With Quote
Old 05-22-2004, 07:01 PM   #5
dinnut
dinnut's Avatar
ooh i like that last one....
70 longbed
496/th400/Ford 9"
dinnut is offline   Reply With Quote
Old 05-22-2004, 07:13 PM   #6
toddtheodd
toddtheodd's Avatar
How do the turn signals and bright indicator work without the circuit board?
Old 05-22-2004, 08:12 PM   #7
neonlarry
neonlarry's Avatar
Check here and see how they hooked them up.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 05-23-2004, 12:02 AM   #8
Wreck
thanks a bunch fellas, that last post was golden. Grease and Ron..those dashes look really good, cant wait till mine looks that good.
Old 05-23-2004, 02:11 AM   #9
68plus4sub
68plus4sub's Avatar
Here's mine, haven't got the hi beam or signal lights in yet, probably going to use small LED's.
1972 Chevrolet Suburban ('68 front clip), 2wd, 350/350, factory tilt
2008 Kawasaki Concours 14
1997 Harley-Davidson Soft Tail Custom
1948 Chevrolet Coupe (project)
1972 Porsche 914
68plus4sub is offline   Reply With Quote
Old 05-23-2004, 08:42 AM   #10
toddtheodd
toddtheodd's Avatar
does anybody sell premade dashes with autometer guages? Maybe with a selection of what you want and where you want it? Electronics confuse the sh** out of me. I can tear a motor down to the bare block and put it back together again in one day, in the dark, but I can't do electrical stuff to save my life.
anybody out there want to fab one for me? let me know how much and I will save up for it.
I want a behind the bezel one like Ron Woodgear's.
I want speedo in top left, tach in top right, fuel (3 3/8) in top center, bottom row in order, volts, water temp, vacuum, oil pressure.
I would prefer the water temp and oil pressure to be of the mechanical kind.
Would prefer black faced, would take grey though. I'll put it in the dash, just include a small diagram of what goes where.
Old 05-23-2004, 11:32 AM   #11
greasemonkey
toddtheodd, they are really simple to hook up. I am by no means an electrical genius, and it was probably one of the simplest jobs I have done. I used some LEDs for the turn signal/bright/brake lights. The dash Ron posted took a lot of work to make as I understand. The guy took off the bezels and fabbed a mount for them somehow. They do look awesome, with the chrome bezel.
There are premade ones out there, but they cost a lot...some do look good though.
If you make your own, shoot Mudder67 and Yukon Jack a PM- they were very helpful to me when I was making mine.
1942 Master Deluxe
1969 C/10
1985 Blazer CUCV
1987 Jimmy
2004 Tahoe
2005 Silverado 1500
2005 Silverado 3500
Old 05-23-2004, 08:13 PM   #12
RON WOODGEARD
There are no 3-3/8" gauges available from Autometer any longer.. Let me rephrase,, They are making no more!!! They have a few On the shelf of the Phantom series, When they are sold the 3-3/8" line has been obsoleted.... (Look at my post and the email sent me from Autometer at "My Old Truck.Com) Summit Racing has a few Fuel Pressure Gauges on the Shelf in the Sport Comp Series, Black face.
You Do Not have to remove the Gauge Bezels, The gauges are attached to the Metal backing that the factory wiring mounts on, and the Factory gauges bolt to. If you look at "Thor50's" dash that I posted, you can see the gauge bezels Silver color between the glass and the factory chromed bezel.. The Gauge Glass becomes the protective glass ( as it is) for the gauge. The factory plastic is not used...
When I first seen Thors, Dash, ( A couple of years ago) I emailed him and he gave me a run down on their install, He didn't do pictures..(Too Bad) I have been playing with an old dash set up to get the install straight before I tear my new bezel up, ( actually there is No Tearing or altering of the factory bezel or the Autometer bezels what so ever)
I have posted on the for sale and wanted to buy area, here, and at My Old Truck.com That I want a 3-3/8" Fuel level, oil pressure, water temp, or clock, in black. If I don't find one, I may just go with Javy's Billet dash.
Old 05-23-2004, 11:54 PM   #13
greasemonkey
I just bought my guages like a month ago, and everyone still had the 3 3/8" mechanical guages. I was not aware that Autometer had discontinued them. And the thing about Thor50's dash, since he has not been around for awhile, I did some extensive research and was told the info about the bezel etc. Didn't mean to give false information, sorry...
John
1942 Master Deluxe
1969 C/10
1985 Blazer CUCV
1987 Jimmy
2004 Tahoe
2005 Silverado 1500
2005 Silverado 3500
Old 05-24-2004, 12:01 AM   #14
Mudder
Mudder's Avatar
I had also talked with Thor50 about how he did his. From what I got, he attached the guages to another plate shaped like the bezel. He mounted that plate to the dash then mounted the bezel over it.
Mudder is offline   Reply With Quote
Old 05-24-2004, 12:35 AM   #15
RON WOODGEARD
John, (Greasemonkey)
Please don't take my post wrong,,, I wasn't slamming you,!!!!!
Where did you get your gauges???? I need one !!!!!!
I have contacted, Summit,Jegs,Napa,Auto Zone,JC Whitney, Autometer themselves,A few E-bay Stores, Even had a friend In Puerto Rico checked his local stores. I'm just not hip, on putting a fuel Pressure in there,, ( I just bought the 2-5/8" one,, It's not here yet even)
I'm hoping to find one Old Stock, or in good used condition.
If I can find the 3-3/8", I'll do a picture summary of how I'm doing it.
Old 05-24-2004, 11:38 AM   #16
greasemonkey
I bought all mine locally at a speed shop..cost a bit more, but I like buying from someone I know. My 3 3/8" is the oil pressure guage #5505.
What kind of guage are you looking for in the 3 3/8" size? I could go ask the shop if they have a supplier that has some still. Let's just say that they have "connections" to many people, lol.
John
1942 Master Deluxe
1969 C/10
1985 Blazer CUCV
1987 Jimmy
2004 Tahoe
2005 Silverado 1500
2005 Silverado 3500
Old 05-24-2004, 12:10 PM   #17
Yukon Jack
Post Whore
Yukon Jack's Avatar
Here is how I did my gauges.
EDIT - MPH guage has now been moved to the left side.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 05-24-2004, 12:51 PM   #18
my new 72
faster, faster, faster
my new 72's Avatar
I hope there is solder under all that electrical tape there Yukon.
I'm going to Law School, wanna debate? It's good practice.
my new 72 is offline   Reply With Quote
Old 05-24-2004, 02:20 PM   #19
Mudder
Mudder's Avatar
I just called Summit with part numbers for all the 3 3/8 guages and they are no longer avaiable from the vender. And they don't have anymore in stock. Thats for the pro comps........
Old 05-24-2004, 03:37 PM   #20
Javy
Javy's Avatar
Hello,
Check out my dash bezel on e-bay.
http://cgi.ebay.com/ws/eBayISAPI.dll...ADME:B:LC:MT:1
Javy is offline   Reply With Quote
Old 05-25-2004, 03:01 PM   #21
Yukon Jack
Post Whore
Yukon Jack's Avatar
Yep, I used solder. Don't want a problem and have to track down the cause.
Old 05-25-2004, 04:23 PM   #22
RON WOODGEARD
I just posted that above,, Didn't you believe me....
I have tried all over.. even checked Auto Zone locally yesterday when I picked up a Tranny gasket, just to be sure...
I would love Javy's but I could buy a few gauges for the cost of the dash and glovebox door.. But If this gauge comes through, I won't need to buy the billet..
I do need a 2-5/8" black faced sport comp fuel gauge still though.....
Old 05-27-2004, 02:49 PM   #23
lewi
lewi's Avatar
Found this in the search this morning and wanted to know if anyone is selling the complete setup ready to go? I would like the original bezel with new gauges, anyone know?
1971 Chevy Cheyenne 383/350 LWB 2wd
Built to use, and look good.
lewi is offline   Reply With Quote
Old 08-05-2004, 12:12 PM   #24
FormerMember
Javy,
How quickly can you get those done?
Any discounts for not having to deal with Ebay's fees?
FormerMember is offline   Reply With Quote
Old 08-05-2004, 12:21 PM   #25
1BadSS
NOT REALLY BANNED!
1BadSS's Avatar
What kind of wheel is that? I think it looks pretty good!
1987 Mustang Coupe - 2.7 Stroker, 78mm turbo, Stainless header, 3" Exh, FMIC, 160lb/hr Injectors, MS3, twin walbro 255's, 34psi. Eating V8's daily.
04 Pontiac GTO
04 Ford Mustang GT
68 C20 LWB stripper truck
73 K5 Cheyenne
76 C20 Sierra Crew SRW
88 K20 Suburban
I'm not hammering on metal just to hammer, i'm creating a piece of art.
1BadSS is offline   Reply With Quote
