Will a 73-78.5 Chevy 4x4 brakeline kit fit a 71 also???
ProComp makes a longer brake line kit for pickups lifted 6". On 4wheelparts.com, it says 73-78.5 1/2 4wd Pickup, Blazer/Jimmy
EXP7215. A lot of other places I've seen 71-78 for line kits.
1972 K-10 Longbox,6" lift w/35's/350/SM465/NP205/3.73 1972 C-10 Longbox,350/350 1998 Pontiac Grand Prix GTP FOR SALE: 1971 K-10 Longbox,350/SM465/NP205 |
I don't know for sure but I would say no. I think NAPA sells brake line tubing in different lengths with the stone guard on it. I hope this helps out. Wes.
Bringing back to the top...
user # 2756
![]() Join Date: Jun 2001
Well the calipers I bought were for a 71-78 chevy 3/4 ton 4 wd as were the rotors. The end of the brake line at the frame should be the same all the way to 87. What changed was the end at the caliper from standard to metric.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs 1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX 1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears 1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now..... 1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone. 1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed. 1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm ![]() |
