need some help QUICK
I am installing a new throttle cable. I ordered a new cable for a 4x4 seeing how my 350 is in the inline 6 position. It looks to be even longer than the cable I removed!!! Will this thing work ??
the new cable is on top and the old inline 6 throttle cable is on the bottom with the mounting bracket
My name's Tim and I'm a truckaholic My 56 Chevy shop truck build http://67-72chevytrucks.com/vboard/s...d.php?t=562795 |
You may be able to get it to work like the one I first used when I put a cle inmine so I had to go out and find something much shorter because it was binding, but it might probally look a little awkward being all cramed to make it work. I thought I read a while back that the 4wd cable was longer than the regular cable something like 11 inches or 3in longer, don't remember.
1967 C10 - SWBSS Pro Street 427sbc, 700R4 & 4.10 Gears 1948 Chevy FleetMaster Coupe, LS1, (almost done) 1950 Chevy StyleLine Coupe 250/6 3x2 Dueces 2009 Toyota Tundra 1996 Harley RoadKing "I maybe getting old, but I can still burn rubber with the best of them" |
blood type; Retumbo
hey Dubie. what carb are you running? where do you plan on attaching at eng? on rear manifold bolt or back of carb. can you find a new one for the six?
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card |
We have a q-jet mounted on top of a 350. We bought the 4x4 cable because all 4x4'x from these years came with the engine in the rear mounted location and thought a new 4x4 cable would work. But it just doesn't look like it's right for this application.
You get the engine running??
HAHAHAHAHAHAHA!!! Right!
Things will work out, trust me. You'll learn what not to do in the process, but it's a learning experience every time. You should see the crankshaft that I twisted.
we're almost at the firing up stage. Just a few more things to hook up and then we can giver a try. Gonna take the day off of working on it and then get at it tomorrow, seeing how it's a holiday in Canada
A holiday? Slackers, you made up a holiday just for general purpose didn't you?
Resident Curmudgeon
![]() Join Date: Dec 1999
Tim, I don't know if these help at all, but here are pics of my 2 near-stock 72 4x4's with the 350. One has an edelbrock carb, the other the OE qjet. Also included is a pic showing engine location in reference to firewall and RH frame.
Currently on or near the homestead: 67 Chevy SWB 2WD stepside 350/3 on tree (Pat's) 67 GMC SWB 2WD Fleet 402/auto (Brian's under construction) 67 Chevy 3/4 ton 2WD 402/auto (Business Hauler) 67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC) 68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC) 70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC) 71 Chevy SWB stepside (Crushed by tree - parts donor) 72 Chevy 3/4 ton 4WD (Parts donor) 72 Chevy 3/4 ton 4WD Suburban (Parts Donor) 72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC) 81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler) 82 Camaro Z/28 355/Super T-10 (Pat's toy) 93 Caprice 9C1 (Brian's Cop Car) 02 Toyota Camry (Reliable but a souless steel and plastic hulk) 2011 2SS RS Camaro M6 Factory Hurst Shifter ![]() Maybe I need to sell some of this crap ![]() Yet another Bozo with a sawz-all |
great!! thanks for those pics Jeff. Can anyone tell me how it re-attaches to the pedal?? It has a small white plastic cone that we can't seem to get to fit right on the pedal bracket
right here |
