05-23-2004, 10:53 AM | #1 |
Many thanks to Swervin and Capt Kaos
I had asked a question on the engine and driveline board about adjusting valve and Capt Kaos had given me the link to Swervin Ervins site. I gotta say, it is the best step by step advice for adjusting valves that I have ever seen. I had the wife read out the instructions as I was tightening away and it went so smooth.
I just wanted to thank Capt Kaos for the link, and also thank Swervin for all his great info. It was a HUGE help
My name's Tim and I'm a truckaholic My 56 Chevy shop truck build http://67-72chevytrucks.com/vboard/s...d.php?t=562795 |
05-23-2004, 05:44 PM | #2 |
www.73-87chevytrucks.com
No problem. Glad to be of help.
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
05-23-2004, 07:07 PM | #3 |
You get what you pay for
Glad you found it helpful.
Mike 1985 Chevy C-10 |
05-24-2004, 12:59 AM | #4 |
huh?
I used it too, when I did the valves on my 406, and I'll be using it again shortly when I put the new cam in....thanks Mike!!!
Someday when I'm lonely, Wishing you weren't so far away, Then I will remember Things we said today. RIP El Jay |
07-01-2004, 01:12 PM | #5 |
Its Magically Delicious
do you have a link ??
71 C10 LWB 350sbc -TH350 12 bolt 3.42 Posi Of all my favorite things to do, The utmost is to have a brew. My love grows for my foamy friend, with each thirst-quenching elbow bend. Beer so frosty, smooth, and cold it's paradise pure liquid gold. Yes beer means many things to me that's all for now cus I gotta pee. |
07-01-2004, 01:14 PM | #6 | |
yeller
http://www.73-87.com/7387garage/drivetrain/valvlash.htm
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
07-01-2004, 02:41 PM | #7 |
Mike (Swervin Ervin) is the man!
I just recently had this on hand along with the service manual when adjusting a few valves. One questions I have for Swervin is: How come you say to do one valve at a time? The service manual instructions only requires you to rotate the engine once and not before each valve adjustment. Does rotating the engine after/before each valve adjustment give you some sort of advantage over adjust half the intake and exhuast, then rotating and doing the other half intake and exhuast? I only needed to adjust two so this really wasnt an issue for me, but if I have to do them all I would like to know why this is. The way the service manual method seems faster, but does swervins method have an advantage? Thanks!
* AVOID: LOPER'S PERMORANCE / LOPERSPEED.COM OF PHOENIX, AZ & COTTMAN TRANSMISSION * |
07-01-2004, 05:18 PM | #8 |
Eddie,
I do a cylinder at a time (intake/exhaust), following the firing order. I have always done my valves this way. There are several different methods in manuals and such. I just prefer to use the firing order method. This method insures both valves are on the heal of the cam and closed like they should be.
