Old 05-23-2004, 02:57 PM   #1
crustysarge
Fuel tank maintenance
I am going to pull the interior soon and ned to order the right stuff so I have it when I start (takes 2-4 weeks to get parts here).
Other than the fuel tank grommet, what other rubber parts should I replace on the tank?
crustysarge is offline   Reply With Quote
Old 05-23-2004, 03:24 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
If you can find it, replace the O-ring on the sendeing unit.
If you have a 71/72, I'd also replace the hoses going up into the pillar on the passenger side too.
Pulling the tank and having it steam cleaned for a few hrs would be a real good idea since you'll have it out. Inspect the filler neck real close for leaks too, that is a common place since it feels natural to lean on the pump handle at the fillin station.
Old 05-23-2004, 03:41 PM   #3
cdowns
cdowns's Avatar
if you're going to have the thing pretty well apart i'd have the tank boiled and pressure tested at the local radiator shop
Old 05-23-2004, 04:07 PM   #4
Longhorn Man
Boiling out doens't do much more than steam cleaning it, and it costs more since it'll take up the whole tank. (We have an in-house rad shop at work)
Old 05-23-2004, 07:04 PM   #5
cdowns
cdowns's Avatar
or don't bother to boil it out and leave all 35years of crap and scale in there so it will cause problems down the road
Old 05-24-2004, 11:53 AM   #6
crustysarge
Thanks for the help!
