05-23-2004, 05:48 PM | #1 |
E.H.F.D Engine #2
Axle Question
What is the difference between a corporate axle and a regular axle? I hear alot of talk about "corporate" axles and have no idea what it means. also how would i know if i had one of these so-called "corporate" axles? THANKS
-NICK '72 K10 SWB Fleetside. Avocado Highlander 350-4speed-NP205 Frame Off Re-Creation '89 GMC V3500 C/C Flatbed Plow Truck 454/SM465/Np205 '15 Chevy 2500HD CCSB High Country Duramax '22 Tahoe Premier Duramax |
05-23-2004, 06:54 PM | #2 |
corporate axles are usually axles made by GM, for example the 10-,12-, and 14-bolt axles are all corporate units.
1969 GMC K2500 1996 Honda Accord 2007 Kawasaki KLR 650 |
05-23-2004, 07:10 PM | #3 |
GM used to use axles made by Eaton and by Dana and such, so the axles were from an outside source. Then GM started making their own axles, the 10 bolt, 12 bolt, and 2 versions of the 14 bolt. They were made by GM so they also got the name Corporate.
GM RPO Codes '95 K1500 4x4 Ext Cab 5.7 TBI NV4500 Tranny, 14 Bolt swapped in, locker, 3.73's |
05-23-2004, 07:18 PM | #4 |
user # 2756
The ones made by Eaton are also refered to as corperate axles, these axles refered to by their RPO code (H052 and H072) are what was available before the legendary GM 14 bolt axle. What you have to watch for is the dana 44 has 10 bolts like the GM 10 bolt axle.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs 1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX 1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears 1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now..... 1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone. 1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed. 1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm |
05-23-2004, 10:18 PM | #5 |
Led Sled! Discs R 4 ME!
This is a good link to help ID your differential housing.
http://www.g-body.org/tnt/diffs/diff-housings.php |
05-24-2004, 12:13 AM | #6 |
Geared for Collision
i noticed the eatons not on that list. the eaton looks like pic attached.
MEMBER OF THE 4 WHEEL DISK BRAKE CLUB 1970 C/K20 3/4 Ton 1996 Collectors Edition Corvette 1977 Corvette Coupe |
05-26-2004, 12:11 PM | #7 |
Thats right Bud!
Just to help the Corporate/eatons Had a round 10 bolt rear cover and a drop out nodular front center section (like the 9" fords). I believe it had a 9-1/2" ring gear. Denny |
05-26-2004, 01:37 PM | #8 |
user # 2756
Make that 10.5". The axle shafts were a hair over 1.5" but had only 17 splines. As comparision the 14 bolt FF and dana 70 are also around 10.5" and have 1.5" axle shafts but more splines.
06-02-2004, 07:15 AM | #9 | |
There are Eaton 9 1/2" out there but now I am unclear as to which is a 9 1/2 and which is a 10 1/2. So far what I come up with is that the FF axles are 10 1/2 and the Semi floaters are 9 1/2 rings with the early 10 bolt cover (14 bolt ring gear) axles. I had two of these rears, both FF. one locker and one open. Now I wished I opened them up. But now I'm not completely sure http://www.akfabshop.com/alaskaoffroad/axle_tech.htm http://www.kldriveline.com/gmdiff9.5.htm |
06-02-2004, 08:25 AM | #10 |
user # 2756
Your right but those are 73 and later axles identified as "14 bolt" axles. The "eaton/corperate" axle w/ round cover and drop out center were only FF and 10.5" ring gear. There were higher GVWR axles similar to the eaton/corperate or H052/H072 that had larger ring gears these were 11000 and I believe 14000 lb axles.
06-02-2004, 12:44 PM | #11 |
Jim, they did in fact make other sizes of eaton axles...pre 67, 1/2 ton trucks had an axle that looked like the HO52 but was semifloat with 6 lugs. I am not sure of the ring gear size of this axle. They also made a bigger version in some 1 ton trucks called the H135 or something like that, it didnt have a removable diff cover and had a 12.25" ring gear. there were also many other sizes that were available in larger trucks.
but for 67-72 3/4 and 1 ton, only the HO52 and HO72, full floaters with 10.5" ring gear. I think the names have something to do with weight capacity, at 5200# and 7200#, but could be wrong.
