Old 05-23-2004, 09:28 PM   #1
aggiedave98
how to get off control arm bolt
Any help on how to get the lower control arm bolt off?? I've wd-40'd it and have a 1/2" breaker bar, but that's not enough. I can't get an impact wrench on it b/c of the exhaust is in the way.
aggiedave98 is offline   Reply With Quote
Old 05-24-2004, 11:17 AM   #2
LONGHAIR
Do you have a way to heat it? Even a propane torch may be enough.
LONGHAIR is offline   Reply With Quote
Old 05-24-2004, 11:37 AM   #3
grayw0lf
Longer breaker bar. Heat it & then put a 2-3ft. piece of pipe over your breaker bar. The longer the pipe, the more leverage you have.
85' CUCV M1009!!! The newest addition!
6.2diesel, Th400, NP208, & only 36k miles!
70' C-10 LWB Fleetside - Looking good these days!
05' Dodge Neon
88' Winner Escape Sport 1750 - 4.3v6
94' Seadoo SP
84' Honda TRX200, bare nekkid. Just a frame & tires.
Always looking for another project or any good deal!
grayw0lf is offline   Reply With Quote
Old 05-24-2004, 10:25 PM   #4
1971 Cheyenne
1971 Cheyenne's Avatar
I used a big pipe wrench and a 4 foot breaker bar with me jumping on the end of it.
Took some work, but i'd have to say getting the new ones on was even more of a chore. LOTS to look forward too
Brian Pal
1971 Cheyenne 10 454/th400-Undergoing a full frame off resto.
1972 Chevy short/step 2wd, 350/th350
1983 M1009 CUCV Military K5 Blazer
1981 Dodge 1 ton 4x4 dually flatbed
1971 Cheyenne is offline   Reply With Quote
Old 05-25-2004, 03:00 AM   #5
1972C10
1972C10's Avatar
Get some penetrating blaster and it will stomp a muddhole where wd40 wont phase it Heat it up with a torch and hit it with some wax that often does the trick on unbearable stuck bolts.
what i always did is put a backer wrench on it and a breaker bar and long pipe if just the breaker wouldnt do the trick, Your not going to break that bolt. So give it hell
1972C10 is offline   Reply With Quote
Old 05-25-2004, 10:08 AM   #6
cdowns
cdowns's Avatar
just get in there with a small cutoff wheel cut the sucker off and it's good to go . you're not planning on reusing the u-bolts that hold the control arm in place are you??
Old 05-25-2004, 12:04 PM   #7
1971 Cheyenne
If he's thinking of the same bolt I am, you really don't want to use a cut-off wheel. Are you thinking of the 4 u-bolts that hold the lower control arom on or the 1 3/8 or 1 5/8 inch nuts that hold in the lower and upper control arm shaft?
Brian Pal
Old 05-25-2004, 12:18 PM   #8
cdowns
cdowns's Avatar
i was thinking of the u-bolts that mount the control arm to the frame,and i've seen more than 1post from members that have had used ones fail that's why i suggest getting new ones
Old 05-25-2004, 09:55 PM   #9
1971 Cheyenne
oh, yes you are right then, There is absolutely no reason to reuse those bolts over again, they are cheap!
I was thinking of these nuts (the ones painted silver/gray)
Brian Pal
Old 05-26-2004, 05:28 AM   #10
Sublvr72
Sublvr72's Avatar
use PB blaster spray. I soaked mine for a few hours and the loosened up with breaker bar. Have you already seperated the lower control arm from the spindle?
Sublvr72 is offline   Reply With Quote
Old 05-26-2004, 11:26 PM   #11
aggiedave98
thanks for all the help!!
I was talking about the 1 1/8" bolts, not the u-bolts. I used a 4' pipe over the breaker bar and was able to break them loose.
Old 05-27-2004, 10:51 AM   #12
slam33
slam33's Avatar
Those are the A-arm shaft caps. There on with about 250 ftlbs. The shaft kits from Moog are about $50. You can get rebiulds for about a $100. As for the caps, set the truck on a jack stand and use a 4 ft breaker bar. When there loose you can pull the a-arms off and replace the shafts and caps.
71 LWB 350/350still working on it but it's going tp be sweet. www.geocities.com/stevemau/slam33page.html
" TARGET=_blank>http://www.geocities.com/stevemau/slam33page.html?1004806705410
</A>
slam33 is offline   Reply With Quote
