Old 05-23-2004, 09:52 PM   #1
68jimmy
68jimmy's Avatar
Routing of emergency brake cables
My 68 gmc came originally with a manual trans behind the v6. I have removed the bellhousing crossmember and installed an auto crossmember. Do the cables for the emergency brakes route under or through/over the auto crossmember?
It would appear that there would be too much interference if they ran under... I figured I better check to be sure.
thanks in advance!
68jimmy is offline   Reply With Quote
Old 05-24-2004, 05:40 PM   #2
flip66
flip66's Avatar
do not know if it well help but there pictures of the routing for a TH400 in this thread.
http://67-72chevytrucks.com/vboard/s...d.php3?t=96923
flip66 is offline   Reply With Quote
Old 05-24-2004, 05:47 PM   #3
adamls
Gotta Startem Early
adamls's Avatar
Anyone ever seen a way to apply the brakes and then lock the hydraulics, that is how my 4 wheeler works. That would be good E-Brake without all the cables and can you get a truck inspected without e-brakes.
67 SWB In Progress, one piece at a time, maybe 3 years I will be finished
adamls is offline   Reply With Quote
Old 05-24-2004, 06:00 PM   #4
flip66
flip66's Avatar
Will not pass in TX on my 69 they were not adjusted right and would not hold if you gave it gas they faild me I had to adjust it. It may have been the place that inspected it though.
