KEEP ON TRUCKING
column rebuild
ive got a auto column non tilt is the bearings all i need to replace or is there other stuff.its just sloppy but i dont know where to do the bearings or if there is other stuff i should replace
72 cheyenne 2wd lwb 71 k20 sons bassett va |
The bearing tend to wear over time. You can usually pick up a good Auto column for under $50. at any yard. Or now might be the perfect time to put in a Van tilt and convert it for your truck--easy stuff and tilting the wheel makes room for a lot of beer and hotdogs----ifin u no what i mean!! (by the time you find the bearings, take the sob apart etc.)
