Old 05-24-2004, 11:54 AM   #1
crustysarge
Column shifter sloppy
As there any way to tighten up the shifter? Sloppy and yhe wife has problems understanding the truck is not in "D" when it only shifts to second...
figured I'd ask before I tear into it.
crustysarge is offline   Reply With Quote
Old 05-24-2004, 12:33 PM   #2
2low72
i was wondering if there is an easy fix for it also??
2014 GMC Yukon XL (Wifey's)
2004 Chevy Silverado Crew Cab Z71
2low72 is offline   Reply With Quote
Old 05-24-2004, 03:02 PM   #3
silvertonguedevil
silvertonguedevil's Avatar
Me Too!
-Greg
My Chevy trucks, past and present:
1962 C10 SB Fleetside
1964 C10 LB Fleetside BBW
1966 C10 SB Fleetside
1966 C10 SB Fleetside BBW
1968 C10 SB Fleetside
1971 C10 LB Fleetside
1971 C10 SB Fleetside
1972 C10 SB Fleetside Cheyenne
1972 C10 SB Fleetside Cheyenne Super
1972 C10 LB Fleetside Cheyenne Super
1974 C20 Cheyenne
1979 K5 Blazer Cheyenne
1982 K10 SB Fleetside Custom Deluxe
1982 K10 SB Fleetside Scottsdale
1986 C10 SB Fleetside Silverado
2008 Silverado 1500 4x4
silvertonguedevil is offline   Reply With Quote
Old 05-24-2004, 03:17 PM   #4
Jeepster376
Jeepster376's Avatar
Replace the bushings in the linkage. there is a link going from the base of the column to the trans, it has a bushing at each end that is most likely gone. replace them and it should be worlds better.
72 Cheyenne Super 4x4 SWB
Jeepster376 is offline   Reply With Quote
Old 05-24-2004, 03:49 PM   #5
hank
where would you find a bushing in good condition? seems like all the junker ones's would be worn out.
hank is offline   Reply With Quote
Old 05-25-2004, 02:04 AM   #6
jimfulco
Get them at the Chevy dealer.
jimfulco is offline   Reply With Quote
Old 05-25-2004, 03:14 AM   #7
crustysarge
Sounbds good except the nearest dealer to me 5,500 miles!!!! Gonna reach here but if anybody has a P/N please give me and I'll have a buddy get them for me. He is not real car savvy but if he has a number he's a whiz.
Old 05-27-2004, 12:36 PM   #8
jimfulco
Might also be an adjustment problem. The local Chevy dealer said their computer only goes back to '77, and that grommet is discontinued anyway. www.mothertruckers.net (parts selector) shows an auto trans shift bushing under "misc. parts". That might be it. Then again, you might find one on an abandoned military truck somewhere
Old 05-27-2004, 04:41 PM   #9
crustysarge
Thanks. Shoot, you will not see any old abandoned military trucks on today's bases. As a matter of fact, been that way for many years. And even if you did, you'd risk your career for taking something. Old times are long gone.
Old 05-27-2004, 07:20 PM   #10
motoretro
There is a HP publication called 350 hydromatic which explains in detail adjusting the linkage which if left sloppy can burn up bands. So it is important...I imagine there is such a book for 400 turbos too....
motoretro
motoretro
1972 Chevrolet Custom 10 Lwb
www.esivart.com/ebay/truck.gif
motoretro is offline   Reply With Quote
Old 05-28-2004, 04:01 PM   #11
No3Fan4Ever
Running on empty
No3Fan4Ever's Avatar
Mine is way beyond sloppy..................Are the bushings available at any of the Restoration Venders???? Wes? Ed? Bill? Anyone else?
We have two rules here at the Rock.
Rule #1: No writing on the walls.
Rule#2: Obey all rules
70 GMC Sierra Grande "Custom Camper" Longhorn 402 Big Block TH400 PS PB factory AC Posi;
94 Bronco XLT 302, auto;worn out daily driver
No3Fan4Ever is offline   Reply With Quote
Old 06-01-2004, 10:52 PM   #12
grayw0lf
Anyone know where to find these elusive parts? Going once... Going twice..
85' CUCV M1009!!! The newest addition!
6.2diesel, Th400, NP208, & only 36k miles!
70' C-10 LWB Fleetside - Looking good these days!
05' Dodge Neon
88' Winner Escape Sport 1750 - 4.3v6
94' Seadoo SP
84' Honda TRX200, bare nekkid. Just a frame & tires.
Always looking for another project or any good deal!
grayw0lf is offline   Reply With Quote
Old 06-01-2004, 10:59 PM   #13
Cat Fuzz
My son, my joy.
Cat Fuzz's Avatar
Oh God forbid if they had to actually use.......A BOOK!!! ::GASP::
Cat Fuzz is offline   Reply With Quote
Old 06-01-2004, 11:20 PM   #14
krue
Designated A-hole!
krue's Avatar
Talk to Piston about tightening the linkages up. He used some tubing and ingenuity to fix his.
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 06-02-2004, 07:54 AM   #15
da-burb
"Ochre Ogre"
da-burb's Avatar
First off, do you still have the spring and washer at the end of the steering shaft and the intermediate shaft? This has been missing in half the trucks I get. It is the only thing that keeps the column from pulling out towards the driver. It also puts tension on the shifter detents. You can sometimes get a little more presure by adjusting this.
Next place to look is the pivot point at the frame. It is an ungreased point and every time you shift it is metal on metal. The hole will oval out and cause much of the slop. Find a washer that fits the pivot and weld it on to take up the slack again.
Re-adjust the down rod and you are set to go again.
Bowtie Truck Stop Inc.
Mid-West GM Truck Restoration Parts Supplier
Your Key Parts, Auto Metal Direct, Dynacorn,
and Goodmark dealer.
like us @ www.facebook.com/BowtieTruckStop
1971 C-10 Suburban (Ochre)
1971 K-10 Suburban (Ochre)
1972 C-10 Suburban (Ochre)
1972 K-20 Suburban (Yellow- that just aint right!)
Springfield, Minnesota 56087
da-burb is offline   Reply With Quote
Old 09-09-2019, 05:34 PM   #16
howell57
Re: Column shifter sloppy
What would I look for if the slop is only the shift lever. Just put a CPP linkage on a 6L80 and can hardly feel the detents. Feels too tight
howell57 is offline   Reply With Quote
