Clutch, Flywheel - 305 to 350 ? - Part #'s?
1983 1/2ton 2wd with 4 speed manual (465)
original with 305 now has 350. Ok guys clutch started slipping about 2-weeks ago. Pulled the trans replaced clutch with beck/arnley 11". Started the truck had rubbing noise, pretty loud all the time. Not sure what caused it pulled the trans again. Couldnt find anything that could have caused it. Going to change to performance clutch this time while everything is apart. Been checking website and catalogs. 305 came with 11" clutch (which I have now with my 350) 350 should have 12" clutch (which is the only performance clutches I can find listed for my truck) The flywheel and bell housing seems to be the same. Can someone verify that the flywheel and bellhousing for a 305 and 350 are the same (not will they work, but are they the same, part #'s maybe)? Here is the issue, when I measure the flywheel to see if a 12" disc will work, its too close to the pressure plate mounting holes. I think its too close for a 12" disc to be in there. SO IS A 12" CLUTCH DISC REALLY 12" OR IS IT LIKE 11-1/2" OR 11-3/4" ? Going to try and contact someone at either jegs & summit to see if they can help. I am also going to try and call a couple of the clutch mfg's. Was hoping you guys may be able to help some. Need to order the parts asap so I can get this finished next weekend. Thanks
* AVOID: LOPER'S PERMORANCE / LOPERSPEED.COM OF PHOENIX, AZ & COTTMAN TRANSMISSION * |
For anyone who sees this later.
From Jegs support the guy told me that the 12" clutches are actually like 11-1/2 to 11-3/4". For 65-84 GM C/K I6-V8 use Zoom Multifriction Clutch Kit (MF55051 - includes pressure plate, disc. and throwout bearing) - 11" disc, 1-1/8" input, 10 spline I am sure you could use a 12" clutch in the truck without changing flywheel or bellhousing as the part numbers are the same (flywheel and bellhousing 305 to 350), but just to be safe I used what zoom recommends for my truck (the 11" MF55051). I was considering the centerforce clutch kits, but they didnt include the throwout bearing and would only show 12" clutch kit for my truck. If anyone knows for sure if a 12" clutch disc is actually smaller, like 11-3/4" please let me know for future reference. thanks. Should have clutch installed this weekend and back on the road ...... I hope
www.73-87chevytrucks.com
![]() Join Date: Dec 1999
Never heard of a 12" clutch for our models. 11.5" was the largest I know if. I can recommend the Zoom Kit though. 305 flywheel should be the same PN as a 350, as you found.
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
