kind of a dumb ques. on this board but her is the only one ive been to but her goes does anyone know how to bleed the clutch on a 84 s10 blazer
http://rick.nicholson.home.insightbb.com |
Gotta Startem Early
I didnt know the 84 Blazer had a hydraulic clutch but if does then I dont know.
67 SWB In Progress, one piece at a time, maybe 3 years I will be finished |
It's a catastrophic success.
![]() Join Date: Jan 2003
The Chilton manual shows a bleeder on the slave cylinder, bleed it like brakes
(pump clutch pedal hold to floor, open bleeder valve,close bleeder valve, repeat) |
SOON TO BE A STEP SIDE
some times when you bleed the slave (just like bleeding brakes) you only get a small amount of fluid out.
once the air is out there doesnt seem to be enough throw on the lever. try this have your helper hold the clutch pedal down then hold the throw out lever with a bar so it cannot return when he lets the pedal off. (the bleeder should be closed) then have him or her press the pedal again and do the same thing by holding the lever and pressing the pedal again fluid is forced into the slave thus giving you a complete throw on the release lever. then you can give it one final air bleed and your pedal should be great just my 2 cents
67 CHEVY LONGBED----- BEST 51 DOLLARS EVER SPENT ON EBAY! 4.3 LITER INJECTED MOTOR WITH 5 SPEED GOING IN SOON |
| Bookmarks |
