05-24-2004, 11:18 PM | #1 |
Beep! Beep!
tubbing a stepside?
i was just wondering if anyone has tubbed a stepside on here, if so, was it a hassle?
72afr
1972 Chevrolet C/10 shortbed, stepside, 350, HEI, Fire Engine Red, Black Interior, Former Army cargo transport 2003 Chevrolet 2500HD CC 6.0 4wd 2004 Jeep Rubicon some aftermarket stuff... 2019 Jeep Unlimited Rubicon (the wife's baby hauler) |
05-25-2004, 08:08 AM | #2 |
take to the top
71 cheyenne 402 th400 swb 71 camper special (PARTS TRUCK) 70 Stepside swb 350 |
05-25-2004, 12:03 PM | #3 |
More Cowbell....
I would like to know about that myself. My current wheel/tire setup will rub the inside of the bed when I take a hard turn. Minitub would be a huge help.
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket |
05-25-2004, 06:00 PM | #4 |
I knew a couple of guys that tubbed stepsides by using fleetside wheel tubs bolted to the inside of the bed.
05-25-2004, 08:40 PM | #5 |
Those do work nicely, you can also cut the bottom from a 50 gallon drum and slit it in half. Cool thing about a 50 gallon drum is that you can make your wheel tubs as wide as you need them.
05-25-2004, 09:51 PM | #6 |
I did it years ago on a 50 studebaker truck. I was the first time I ever used a plasma cutter. It did a beautiful job of cutting the radius. I used the steel tubs from Jeg's for the wheel wells. The inside of step-side beds are easier than many vehicles because the bed sides are straight.
05-25-2004, 11:50 PM | #7 |
huh ???
I saw one at a car show one time where the guy used a right side rear step fender as a left side tub and a left fender as a right side tub. I thought it looked wild as s#*t...
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's "I am a bomb technician. If you see me running try to keep up!" |
