shackle flip how to ??s
have any of you done it. if so did you buy a kit or make your own. im thinking about building my own. anyone have a good starting point...drawings sketches measurements or pictures. i have access to steel decent welding skills and will have lots of time when i get laid off pretty soon.
any help would be appreciated thanks stan
79 chevy k20 350/350/205/D44/14bFF 4.56 gears rock ![]() LWB pimer black 01 S-10 ZR2 extended cab 4.3/4L60E/233 3.73 gear 31" DICK CEPEK CRUSHERS |
I'm using a Off Road Design Shackle Flip, not installed yet so I can't comment on the install. I like to build things myself as much as possible, but when it comes to suspension and brakes I prefer the known and tested. I looked at using a stock hanger from a GM truck but I wasn't sure what kind of lift I'd end up with. So far ORD has been great on support.
Larry 72 Chevy SWB 4x4 71 Chevy SWB 4x4 My Work Truck "Don't confuse enthusiasm with capability" |
you can cut a slot in your old rear bracket and just flip the shackle, it doesnt look strong enough to me, and doesnt look like it would allow enough flex. you can also take a front spring mount (front mount on the rear suspension) and mount it at the rear of the rear suspension. or you could go with ORD.... there is another maker of shackle flip kits, but last i heard he was extremely backed up and having problems. Check coloradok5.com for more info on this.
The only draw back to the shackle flip is it moves your axle forward a little more in the wheel well. 67-72 already sit kind of forward in the wheel well without that.
Land Beast
http://community.webshots.com/photo/...32958157uIvqWR
I really don't think it moved the axle all that much I can't even tell.
90' GMC 1 Ton Suburban |
Shackle Reversal
I used the stock GM front rear spring hangers.
Real Trucks are Built not Bought Building: 1981 GM SB LowRider 1985 GM K3500 3+3 1981 GM K2500 SSB 1980 GM K2500 X-BC Hydro 1979 GM K3500 3+3 1976 GM K5 Blazer 1970 Custom 10 http://bc4x4.com/ Last edited by Truckstuff; 05-26-2004 at 10:07 AM. |
Here are some previous posts I have helped this question out with..
http://67-72chevytrucks.com/vboard/s...threadid=77878 http://67-72chevytrucks.com/vboard/s...threadid=83104 http://67-72chevytrucks.com/vboard/s...threadid=75444
Support The Board Last edited by drink2mny; 12-24-2005 at 05:02 AM. |
Geared for Collision
if worried about where tire sits in wheelwell someone showed me the link below which is what i got that allows you too change the offset.
http://www.offroaddesign.com/catalog/Zero%20Rates.htm
MEMBER OF THE 4 WHEEL DISK BRAKE CLUB 1970 C/K20 3/4 Ton 1996 Collectors Edition Corvette 1977 Corvette Coupe |
drink2mny & Truckstuff
that looks alot easier than cutting and welding a bunch of stuff up. all you had to buy is bolts? my truck is a 79 1/2 ton [10 front 12 rear] the axles im going to use are 77 3/4 ton [d44 front 14 rear] when i take out teh axles on the 77 will those front shackles work or will i need to have 1/2 ton shackles.
basically are 1/2 and 3/4 different. id like to combine the 2 trucks together to make one that i can beat on a little without destroying to much stuff thanks stan
Budweis
im no master fabricator but that zero rate thing looks like something that couldbe made pretty easy with just a drill and a tape measure. ill make one if i need to move the axle.
Truckstuff drink2mny did you just hook the new shackle on and hold it up to the frame to figure out where to mount it or is it more involved than that? stan
#11 | |
I believe I used 2 or 1 existing holes on the frame from where the old perch was.. Took a day to install this is a thread i had when I was selling some perches. I still have them for sale.. The pics don't come up sice the rebuild of this site. But i could probably get some.. http://67-72chevytrucks.net/vboard/s...d.php3?t=99425
Support The Board |
More/Less Mark the center of the top shackle mount on the old one, on the frame. C-clamp the new one in place at the center of it. Install springs, Axle, etc. so the weight of the truck is on it. Check shackle angle before permently mounting it.
Real Trucks are Built not Bought Building: 1981 GM SB LowRider 1985 GM K3500 3+3 1981 GM K2500 SSB 1980 GM K2500 X-BC Hydro 1979 GM K3500 3+3 1976 GM K5 Blazer 1970 Custom 10 http://bc4x4.com/ |
#13 |
Mudslides 'r my specialty
How much lift would a shackle flip provide for a 2wd lwb with heavy duty springs?
Always on the lookout for old cars and parts...(20s, 30s, 40s, 50s, 60s, etc.) http://www.cardomain.com/memberpage/500339 |
#14 |
pretty much any of the shackle flips you use will give you about 4in of lift..
Can I ask, why the intrest to put on a 2wd?? Making a prerunner??
Support The Board |
#15 |
Thinking about it...4 in. might be too much for me. I am looking for about 2 in. or so.
#16 |
i believe that ORD offers a 2 or 2.5" lift and a 4" lift. you might look into it.
#17 |
What was I thinking??
Ecobit Made a deal that bolted to the bottom of your spring hanger and would give you about 5in of lift seeing how Chevys have the saggy butt going on it makes sence for add one inch.
All you did was bolt his deal in place and swapped the shackels and you were done. But he is the one that went out of business. which is to bad from what I heard it worked quite good. Cethern
72 K5 that needs lots of parts.. 71 GMC 3/4 4x4 That doesn't need much which is a good thing I don't think I could aford another money pit... |
