Found some rims
I was visiting a friend in Swan Hills, Alberta, over the weekend, and after testing the new Jeep in the thick stuff, I found out I needed hungrier tires to have any real fun. So he told me about these old Camaro 14"s he had laying around.
I took them home, and planned on drilling the Jeep bolt circle into the face, making it a 10-hole Chevy/Mopar universal. Turns out, Jeep needed the 15"s for a reason, and they little Camaro turbines will never clear the brakes. I still want to use them on my Chevy though. So before I get myself too worked up, will these fit over stock Chevy C10 brakes? I'm going to try them when I get home tonight, but I'd still like to know in the mean time, if you can tell me. If they do fit, they won't be getting off-road tires. There's not much point with a 2-WD. Something meaty, but not knobby. Actually, probably an all-terain/all-season, since I only drive this thing in the winter. ![]() ![]() ![]()
'86 C10 regular cab, 383 on propane www.cardomain.com/id/doasa '87 TurboCoupe 2.3Turbo intercooled 5-spd www.cardomain.com/id/oldraven '93 Jeep Grand Cherokee 4.0L |
Bolt pattern is different 5 on 4 3/4" on cars trucks are 5 on 5".
matt |
Would it still be worth drilling the 5" bolt circle? Seems a shame to let these rims go to waste.
LED King
You need 15" rims to clear the brakes. 14" is a no go.
Tyler 1985 C10 305 w/ Bowtie OD TH700R4 3.42 LSD 202,000 miles 2006 Ford Focus ZX3 5-speed Stick 2016 Chevy Spark EV Gone: 2002.5 VW GTI 24v VR6 Gone: 2008 VW R32 |
****e! What am I going to do with these things? e-bay, I guess.
Mudslides 'r my specialty
Either way, I don't think you should ever "add" your own holes to a wheel engineered to only have 5 holes in it, unless you have access to finite element analysis software, especially for a 3,800 pound truck.
Always on the lookout for old cars and parts...(20s, 30s, 40s, 50s, 60s, etc.) http://www.cardomain.com/memberpage/500339 |
Would the billet bolt pattern adapters work?
Kent Ballan ANY MAN CAN BUILD A TRUCK, BUT IT TAKES A REAL MAN TO CUT ONE UP! ![]() ![]() ![]() |
