05-25-2004, 12:46 PM | #1 |
FS: LOTS OF STUFF! Bodies, wheels, tires, lift kits
*** 33x12.50x16 Super Swampers on 16x10 8 lug wheels
These are BRAND NEW. 33x12.50x16 Super Swamper Trxus Radial Mud Terrains on 16x10 Eagle 101 (stonecrusher) aluminum wheels. Wheels are 8 on 6.5. All mounted and balanced. Friend got them for his truck and they rubbed to much. Havent driven on them for more than 20 feet! BRAND NEW $1050 for the set of four, includes center caps, lug nuts, etc. http://community.webshots.com/photo/...28406574tqhwJE http://community.webshots.com/photo/...28406624BFZbDH http://community.webshots.com/photo/...28406605CIVdHo ***1989 Blazer body/tub. RUST FREE and STRAIGHT! This is in excellents shape. I doubt you will find a cleaner body/tub. Tub only! ***4.10 Gears for 14b semi float rear... Like new, still have the marking compound on them. $100 for the set. ***6" Lift Kit and Weld wheels for sale will fit '99-2004 1/2T chevy 4x4. Everything is COMPLETE and in good shape. 6" lift kit with dual shocks up front, rear blocks, EVERYTHING is here. Have camber kits, shocks, all drop downs, all bolts, etc. Weld Super Single II wheels. 16.5x9.75 chevy 6 lug. Good shape with the exception of a small scuff on the lip of a wheel. $1500 takes it all. Will ship. ***4" Lift Kit for 88-98 Chevy 1/2T ** 4" Trailmaster lift kit for a 88-98 Chevy 1/2T truck. GREAT shape. complete with shocks, etc. Also have aluminum skid plate. $1000 obo ***Aluminum 10bolt Diff Cover Con-0Ferr brand aluminum diff cover. Good shape, satin finish. Has drain plug. Fits 10 bolt rear. $60 shipped ***S-10 rear axle and like new alternator Rear axle complete and in good shape. 3.42's open. $100 Alternator great shape, almost new, from a 4cyl. $30 ***1976 K5 Blazer 1976 K5 Blazer 4x4 4" lift 35x14.50x15 Mickey Thompsons 40% Aluminum wheels (have seen better days) rebuilt TH350 K case w/transgo shift kit Engine is a 350 out of a ealry 70's Z28 NP203 New warn preumium hubs 12b rear w/3.73's D44 front w/3.73's Runs good. Good trail beater. Body is straight but has some rust here and there. Was gonna hack it up and beat on it, but moved on to other projects Steering box leaks, but comes with another. Comes with a set of extra wind wing windows also. He is asking $1500 obo ***TIRES: ** (3) 38.5x16x15 Swamper SXs good for spares, have little tread, $30 each ** (1) 35x12.50x15 Swamper Radial SSR. Used for spare, little tread, mounted on 6 lug steel wheel. $50 ** (1)36x12.50x16 Swamper Radial, spare, little tread, $40 ** (4) Stock blazer wheels with center caps and beauty rings set of four $100 ** (2) 35x12.50x16 BFG All Terrain KO's with about 90% tread $200 for the pair! ***MISC.*** ** Front Clip - 1979 chevy truck no rust, complete minus hood. $100 ** HURST SHIFTER - handle and boot, great shape $25 ** SUBURBAN INTERIOR TRIM - trim pieces (blue) from an 88 suburban $50 ** Borla Stainless Muffler 19"x9.5" $50 ** Roll pan 88-99 brand new, with licens plate box. $150 shipped. ** Tail light fillers for a 88-98 chevy truck. Sir Michaels, brand new still in box. $80 shipped ** F150 stock upper and lower control arms, complete $100/set ** 1999 chevy S-10 bench seat, gray cloth, like brand new. $100 ** 1999 chevy S-10 stock lenses (in grill/parking light or turn signal, cant remember ) $25/pair |
06-03-2004, 04:10 PM | #2 |
Is the roll pan a Sir Michaels, if not is it steel? Do you have any pics?
06-04-2004, 09:07 AM | #3 |
Yes it is a sir michaels pan. You want it?
