4" Lift Bump Steer
Just installed a 4" Superlift (springs) and now when my pass. front tire hits a bump, the truck jerks violently. What gives?
1985 GMC K1500 350 700r4 NP208 3.73 |
Did you get a raised steering arm or a dropped pitman arm??
If not that could be part of your problem..
Support The Board |
Steering arm.
Well I'll be one of the first to introduce you to the world of lifted chevy trucks..
![]() Anything that changes the geomotry of a stock steering setup plus adding larger and possible wider tires will cause bump steer.. That is why a good amount of folks go to the crossover steering. It eliminates 90% of bump steer.. You could try a dual steering stabilizer, but that will just cover a problem ..
Support The Board |
