Old 05-25-2004, 07:00 PM   #1
jamie72
jamie72's Avatar
tilt teardown...
how hard is it to teardown a tilt coulm?? it has a little slop in it,trying to fix it..
thanks jamie
jamie72
72 BB cheyenne -- Restoration getting started..
member #807
http://www.myspace.com/whitetailobsession
www.antlertalk.com
jamie72 is offline   Reply With Quote
Old 05-25-2004, 07:48 PM   #2
ljbear
ljbear's Avatar
It's not that difficult. There have been several very good posts on the message board that can get you through it. I tried a search but didn't find the thread I was after. If you have a shop manual it has a pretty good description of the teardown and assembly. Try a search or post on the message board.
Larry
72 Chevy SWB 4x4
71 Chevy SWB 4x4
My Work Truck
"Don't confuse enthusiasm with capability"
ljbear is offline   Reply With Quote
Old 05-25-2004, 08:08 PM   #3
68 chevy truck-TPI
A WORK IN PROGRESS
68 chevy truck-TPI's Avatar
tilt rebuild
were are you getting the parts to rebuild you tilt? can you buy a kit for it?
do you need any special tools?
68 chevy truck-TPI is offline   Reply With Quote
Old 05-25-2004, 08:30 PM   #4
ljbear
ljbear's Avatar
The lower bearing is available from GM and aftermarket. The two upper bearings are available aftermarket. You will need a puller and some basic hand tools as a minimum. The assembly manual list some specialty tools that you can get from a tool or auto supply, but if you are creative you can probably make them yourself.
Larry
72 Chevy SWB 4x4
71 Chevy SWB 4x4
My Work Truck
Old 05-25-2004, 11:02 PM   #5
BtnkBndt
Pennyless Fool
BtnkBndt's Avatar
Here's some pics I took and posted a while back, hope this helps. The original post seems to have flown the coop?
"Who owns this car with the peace sign, the mag wheels, and four on the floor?"
67 Short Step
283/TH400/4.11
BtnkBndt is offline   Reply With Quote
Old 05-25-2004, 11:19 PM   #6
71swb4x4
71swb4x4's Avatar
Here is the diagram from the service manual.
It also has instructions on how to take it apart.
Shawn
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 05-26-2004, 06:32 AM   #7
JimKshortstep4x4
Smile
Btnkbndt,
Nice pictures and instructions. That should be put into the FAQ section along with the illustrated breakdown.
I have never been able to find the inner race for the upper bearing. The lower bearing and race is available. The upper bearing is available without the inner race so if the inner is bad, it could be a problem. I ended up polishing an inner race so that I could have a good one.
Jim
