i love summertime
Wtf!!!! Need Help !!!
WOW ive about had it, im down at my dads house, i got the 67 all ready to go back home with me and i fire up the truck and turn on the lights and no damn running lights, signals and brake lights work great but no running lights, they worked fine 10 minutes earlier when i got gas down the road, what gives? i put a couple new fuses in but it didnt help, i popped the bulbs out and im not getting any power to the running light contact in the light socket....i guess after work tomorrow ill mess around with it but im just fried like im at the point where im ready to say fuk it and kill myself, if it isnt one thing its something else....
if anyone has any pointers to get me started in the right place for tomorrow that would be great thanks, DEREK
1967 shortbox stepside Chevy, 365 hp 327, th400. GLOVE BOX LIGHTS FORSALE, click link for info http://67-72chevytrucks.com/vboard/s...d.php?t=273724 |
![]() Join Date: Feb 2001
I had problems with my headlights going out on me going down the highway. Talk about a trip..............
Member since 2000
Check all your connections. Disconnect the head light and turn the switch on and see if the fuse pops. Either your light switch is fubar or you got faulty wiring. If it doesn't pop then you know the source is at the lights themselfs. make sure all your grounds strap are good. take your time. The wiring in these trucks is cake.
Lights
Check your connector block at the fire wall if this is original the conecters in the plug get dirty or corroatedcleen them up with contact cleaner and put some electrical greese on all the conectors and the plug to keep out moisture Good Luck EMMETT
![]() ![]() ![]() ![]() ![]() Kaukauna WI Airplaines don't land here they are sucked down |
huh?
![]() Join Date: May 2000
I agree, check your connectors, and all your grounds. Then go from there.
Good luck.
Someday when I'm lonely, Wishing you weren't so far away, Then I will remember Things we said today. RIP El Jay |
Recently bought my truck and made it from Springfield, MO to Tempe, AZ w/out a problem day later the electrical system started doing all sorts of strange things. Turns out most of the wires had be cut and twisted together about every foot and a half or so (great repair work done by previous owner). Very weak current from the alt. I Ripped most of the wiring out. Put new wire in with much better connections, haven't had a problem since.
Hard to tell what it was at first, then took of what seamed like pounds of electrical tape. 'Surprise surprise surprise'.
'71 C10 swb 350sb/700r4 |
Well that is a bummer! I'm thinkin a dead short possibly and or the above mentioned, do the fuses keep blowing Derek?
I got a dollar in my pocket that says it is the dimmer switch or the dimmer switch connection.
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
^,me too, most headlight problems stem from the dimmer switch.
![]() ![]() 99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs 95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI |
i love summertime
my head lights are fine, its the running lights on the rear of the truck,
thanks for the help so far guys
The Blazer King
IT IS THE SWITCH!!! Mine does it every time i put on the lights. Head lights come on but no parking, tail and sometimes dash lights. I just twist the knob left to right while looking in my mirror at the marker light. It always comes on.
72 2wd Blazer. Its the superbichinest, megacoolinest, superflowinest. |
