05-26-2004, 08:53 AM | #1 |
86 Silverado Q's
I am posting this for a friend.
Some days the 305 runs good, some days it runs like crap. It misses once in a while and lacks power(a lot). Plugs, wires, cap and rotor have all been changed. Timing is alright. Could it be a valve sticking, carb adjustment, or anything else? Could it be emissions, and if so, what could it be? Also, what year did Vortec heads come out(305 and 350)? Thanks in advance...
1972 C10 1972 C20 |
05-26-2004, 09:39 AM | #2 |
Try new fuel filters,
Check fuel pump pressure/flow Electronic choke may be working erratically Sounds like what I was dealing with on the 82 and cjust took tweak and going through the carb/choke settings. I'm in the hot south, so most of my problems cleared up when I pulled the new electrical choke out and just ran it wired open all the time. Not sure how that would work up there since you folks only have a week or two for spring and summer. Does sound like a carb issue though.
05-26-2004, 09:58 AM | #3 |
Thanks for the info. It has a new fuel filter. Any other ideas? A lot of Sea Foam has been run through the carb...
1972 C10 1972 C20 |
05-26-2004, 11:32 AM | #4 | |
www.73-87chevytrucks.com
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com Last edited by Captkaos; 05-26-2004 at 11:37 AM. |
05-26-2004, 05:36 PM | #5 |
Had that problem one time turned out to be control modual in the dist. check the wire goign to the modual the go bad too.
05-26-2004, 10:52 PM | #6 |
I bet it is the stupid ESC, electronic spark control. Mine acted up on me and left me dead in the middle of a 4 lane hiway, twice. There is a way to bypass it, which I did. I think there is an article about this on Jeff's website. Look here http://www.73-87.com/7387garage/drivetrain/escrepl.htm
Gary -1986 SWB: lowered 4/6, SOLD!!! -Best 1/4 mile: 14.51 @ 91.01 MPH -2001 Pewter Tahoe, billet grill, Corsa Sport Cat-back, K&N FIPK SOLD!!! -2004 Z-71 Extended cab with a flowmaster, BDS 6.5", 3" BL, 35x12.5x18 Trail Grapplers on Pro-Comp 18x9 wheels Last edited by gldevall; 05-26-2004 at 10:54 PM. |
05-27-2004, 06:42 AM | #7 |
Active Member
I second the module idea. I had an erratic idle-only misfire, would almost die like all cyl's cut out at once. Changed the module (and coil, too FWIW) and bingo! No misfire and stronger revving on a stock Goodwrench 350. I got mine from Summitt with their hi-po coil/module, but even a good stock replacement would likely do it, since you've largely ruled out fuel issues...though the pump is a possibility. Even if it were all three, they aren't real expensive (I think the '86 still has a mechanical pump?)
Could be the ESC as gldevall says, but since I don't have one I can't comment. Brian |
05-28-2004, 08:12 AM | #8 |
Again, typing for a friend...
Thanks for the ideas, I will try them out. Was the ESC on an '86? H engine 305 maybe? Thanks
1972 C10 1972 C20 |
05-28-2004, 08:13 AM | #9 | |
Gary -1986 SWB: lowered 4/6, SOLD!!! -Best 1/4 mile: 14.51 @ 91.01 MPH -2001 Pewter Tahoe, billet grill, Corsa Sport Cat-back, K&N FIPK SOLD!!! -2004 Z-71 Extended cab with a flowmaster, BDS 6.5", 3" BL, 35x12.5x18 Trail Grapplers on Pro-Comp 18x9 wheels |
05-28-2004, 02:28 PM | #10 |
In regards to the ESC, all u have to do is disconect the knock sensor and it can't do anything. THats all i did for my truck, that and disconect the vacum sensor, which was unessesary.
'96 Nissan Pathfinder '02 Firebird Trans Am. '88 K5 Blazer |
