Wiring For Dummies??
Anyone know if there is a good book I can buy on auto wiring? I called a buddy the other night and he gave me a wiring diagram for 67-72 trucks so I am cool with that part, but i would like to know more about relays, stereos, etc... anyone have a suggestion on readin material?
My name's Tim and I'm a truckaholic My 56 Chevy shop truck build http://67-72chevytrucks.com/vboard/s...d.php?t=562795 |
Professional Grade
If you really think about it, electrical is actually really simple, its just a bunch of loops, with one end being on the positive eventually, and one end on the negative eventually
![]() Most of it should be color coded (not in my case, lol) and just needs you to sit down for a couple hours to make it all nice and such... Just make sure that you solder and shrink sleeve all your connections to prevent shorts, Electrical tape works too, but will eventually grow old and fall off. If you've got any questions, just send me a copy of that diagram, and pm with em!
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) |
There are books out there. Have a look in something like Barnes & Noble the next time you go south in the USA. Lots of the large soft cover type books on all sorts of auto issues including electrical stuff. They sure are getting a lot more expensive however. I remember when I got stuff like that for $5 and now they are more likely to be $25 and up.
1968 Chevy - 292 with a powerglide |
"automotive electrical handbook" by jim horner $14.95 avalable thru speedway motors is a pretty good book taking you thru theory as well as real wiring problems and solutions
Check out Painless sight under Tech Books, I was trying to see if it was possible to download one of their wiring diagrams, They also have a BBS for posting questions.
http://www.painlessperformance.com/ Found the link to download the PDF for their wiring kit for the GM Truck http://www.painlessperformance.com/M...0510Manual.pdf
1967 C10 - SWBSS Pro Street 427sbc, 700R4 & 4.10 Gears 1948 Chevy FleetMaster Coupe, LS1, (almost done) 1950 Chevy StyleLine Coupe 250/6 3x2 Dueces 2009 Toyota Tundra 1996 Harley RoadKing "I maybe getting old, but I can still burn rubber with the best of them" Last edited by Bowtie67; 05-26-2004 at 04:25 PM. |
What was I thinking??
heres a site
I did a quick search one of the place's I found was MotorBook the price on the book you mite need is a little high I think. But now that I think about it you can find the same book at Autozone and Checkers.
Ceth
72 K5 that needs lots of parts.. 71 GMC 3/4 4x4 That doesn't need much which is a good thing I don't think I could aford another money pit... |
A splendid one to behold
anybody know of a site or book that can give me the lowdown on basic wiring of relays (for electric fuel pumps, fans, etc)?
i know basic wiring, but have never messed with relays really
67 swb 02 wrx |
My other Love
Hmm Im not sure who makes the books, but I got a relay wiring book that has everything from door locks, to alarms, fog lights polarty reversing and other goodies from DLC electronics
![]() Castlegar B.C.The great white North (Canada Eh!) Hooter_5@hotmail.com First generation Monte Carlo club pictures of my life |
Member since 2000
I got something for you, it's a complete book about car alarms and relays, lots of good info.......PM me your addy and I'll have it sent out on monday. I don't need the book cause I do custom audio and car alarm for living at the moment.
#10 | |
Relays are pretty simple once you grasp it. Just think of it as a remote controlled toggle switch. Just like a basic (SPDT) toggle switch, it will have three connectors, Common, Normally Open, and Normally Closed. The relay has two more connectors witch connect to it's electromagnetic coil. When you apply 12 v to the coil it flips the toggle switch. When the 12 v is removed from the coil the switch flips back. The Common is connected to the normally closed connector when it's at rest, and flips to being connected to the Normally open connector when it's energized. To power an electric fan for example, you would ignore the normally closed connector, Connect the common to your battery power source, and the N.O. connector to the fan's positive wire, ground the fan's negative wire. Now when you apply power to the coil, N.O. connects to common, and the fan is powered. Now that the fan is controlled by the low current coil, you can get crafty as to how you power the coil. Like for example connect one side to ignition, and the other side to a temperature switch, and the fan will operate only when the ignition is on and the temperature is above XXX degrees.
72 Cheyenne Super 4x4 SWB |
blood type; Retumbo
go to a local vo-tech school library & look for books on D.C. electronics. may be expensive but should have more than enough info. or if you want just PM me & I will open the book in my head for you. much cheaper that way.
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card |
#12 | |
WHYBYNU when old will do?
-72 Chevy C10 Stepside -2002 Chevy Silverado 2500HD 4x4 -1984 Jeep CJ7 -1995 Polaris XCR600 Custom -2003 Honda 300ex |
