Old 05-26-2004, 11:53 AM   #1
Rod
front spindle reaming for larger ball joint?
Anyone ever try reaming a front spindle taper to accept larger ball joints. Had a call about a 64 3/4 ton truck being converted to 1 ton and the taper of the spindle was not tapered deep enough to accept a larger ball joint.
One option the mechaic was thinking about was reaming the spindle to accept the larger tapered ball joint... lots of meat on the spndle to play with. It may be cheaper cost to do it that way then to swap everything.
Thought I'd ask the mebers if they had any experience with this.
Senior active founding member.
70 3/4 ton GMC Suburban 4x4 250/4 spd.
71 1/2 ton Suburban Chevy 4x4, 350/350
72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane
2005 FLSTSCI Harley Springer
85 FXSB Harley Lowrider
72 Triumph 650 Bonneville 5spd
"Poor people don't have hobbies" Quote from wife.
Rod is offline   Reply With Quote
Old 05-26-2004, 12:45 PM   #2
JimKshortstep4x4
Smile
If the spindle is not hard, reaming with the right reamer should work very well. It would take a good machinest to fixture the part during reaming so that the newly reamed hole is in the right location. If it were reamed off center there would be problems with alignment.
Jim
Old 05-26-2004, 12:49 PM   #3
Shane
Shane's Avatar
The problem with this is gonna be finding the correct Taper Reamer. I would suspect, from my experience as a machinist, that ball joint tapers are not offered as a standard for taper-reamers.
Just a thought to consider because custom made tooling is very very expensive.
Shane is offline   Reply With Quote
Old 05-26-2004, 01:38 PM   #4
Primed67
Primed67's Avatar
We have customers do it all the time on the circle track cars. I know there has to be several different reamers out there but all we sale are the 1-1/2" Taper per foot.
1969 Chevrolet SWB Stepside
1959 Chevrolet apache * Sold
1967 Prostreet Chevy SWB Fleetside *Sold
2014 1/2 ton Crew Cab Chevrolet 4x4
Primed67 is offline   Reply With Quote
Old 05-26-2004, 11:56 PM   #5
Rod
OK.. thanks for the tips... I'll see what he comes up with.
Old 05-27-2004, 09:56 AM   #6
Erl
Erl's Avatar
www.goodson.com has the reamer you are looking for. You can sometimes find a ball joint from another type of vehicle. I am using an 80's blazer tie rod end on my 68 4x4 power steering conversion. I was going to ream the steering arm, but found a drop-in replacement.
Erl
1968 GMC 305 V6 3/4 4x4 Stepside
06 Corvette Daily Driver
Dallas TX
Erl is offline   Reply With Quote
Old 05-27-2004, 11:17 AM   #7
Ole Blue
Yes circle track guys do it all the time. Check with some of the circle track vendors for the reamer. Very easy mod to do yourself. No fixture needed as you already have a hole to start with. No problem with alignment. I can't count the number of times I've done this. If you need help with details or vendor let me know.
Ole Blue is offline   Reply With Quote
