17 inch wheels for my 67 short fleet
Does anyone know what offset I need I am looking for 17x8
Kevin Special Thanks to All who have helped on the TRUCK! My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4 So Far my best Times are: Motor only: 6.44 1/8 @ 104.13 10.39 1/4 @ 125.83 Nitrous Times: 5.785 1/8 @ 118.65 with a 1.336 60ft 9.168 1/4 @ 142.58 with a 250 shot dead out of the hole! |
i`ve seen some 17x8 wheels with a 5 inch backspacing fit a 275/60/17 tire. if i remember right, thats what fuelcellguy was running. hope this helps.
Anthony |
4.5-5" work well on 67-72's. What size tires are you considering? Is tire rotation a consideration?
I'll probably run 275-60-17
I was told that a 67-68 had a narrower rearend!
