Old 05-26-2004, 09:22 PM   #1
dion
72 Cheyenne
dion's Avatar
fuel gauge question
my gauge stopped working so I checked the sending unit (it's good) swapped the gauge with a working one but it still won't work, we tested everything we could think of. Any ideas? I'm thinking maybe the circut board is bad?
Burnout
Idle
1972Cheyenne
1966/67Stouts
dion is offline   Reply With Quote
Old 05-26-2004, 09:27 PM   #2
caspear78
caspear78's Avatar
Location: biwabik, minnesota, what is this white stuff out here
have u checked the wire going from the tank to the fuse block?
caspear78 is offline   Reply With Quote
Old 05-26-2004, 09:30 PM   #3
dion
72 Cheyenne
dion's Avatar
yup, still nada
Burnout
Idle
1972Cheyenne
1966/67Stouts
Old 05-26-2004, 09:34 PM   #4
smitty62
smitty62's Avatar
Try a new temporary ground at the tank itself--if that works you can then replace with a permanent one.
Stepsides look like real trucks!
Smitty
smitty62 is offline   Reply With Quote
Old 05-26-2004, 10:46 PM   #5
ksamps01
I had the same problem once. I drove me nuts until i found a layer of corrosion on the mating surface of one of the nuts that connect the post to the circuit board. Scraped it off and everything is happy.
1967 Chevy LWB Fleetside
350/400 (Worn Smooth Out)
Resto in progress
It may be ugly but at least it's slow!!
ksamps01 is offline   Reply With Quote
