Old 05-26-2004, 11:18 PM   #1
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
Suggestions for aftermarket A/C system?
I plan on putting an aftermarket A/C system in the 68 before it goes to paint, or at least have it set up and ready to install. My requirements (if they can be met):
Factory vents, factory control panel, and nothing but a bulkhead on the firewall in the engine compartment.
I am going to shave and smooth the firewall, so a factory system is out of the question.
I have been told that Vintage Air will not work with a completely smooth firewall.
Hot Rod Air has been recommended, but at this time they do not advertise a kit for our trucks.
Any other thoughts?
Thanks!
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 05-26-2004, 11:25 PM   #2
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
May want to try old aire product's..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 05-26-2004, 11:47 PM   #3
glock35ipsc
Thanks alot, I'll look them up!
Bob
Old 05-27-2004, 10:20 AM   #4
jorgensensc
jorgensensc's Avatar
How smooth of a firewall do you want? You can forego using the plastic piece that comes with the Vintage kit if you just want the hoses to come through the firewall and you fill in the old gaps for the heater box. I just did a Vintage Air install and thought it was a breeze to install (took 1 day including removal of the old system). I went with the factory style controller and thefactory vents. It looks great and Really blows cold.
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
Old 05-27-2004, 10:29 AM   #5
lock
Insert funny comment.
lock's Avatar
Got any pics Jorgensensc?
- Mark
-My Build Thread...
-68 C10, LT1 - Undergoing Frame off resto
-86 IROC-Z T72 turbo 355, M6
-70 Camaro
http://www.iroc-ss.com
lock is offline   Reply With Quote
Old 05-27-2004, 10:35 AM   #6
Shane
Shane's Avatar
You are correct .... Hot Rod Air does not offer a kit specifically for OUR trucks. But you can purchase one of their Street Rod kits and it will do all that you stated above.
They are who I plan on using. http://www.hotrodair.com/pg1a.cfm
Shane is offline   Reply With Quote
Old 05-27-2004, 10:48 AM   #7
adamls
Gotta Startem Early
adamls's Avatar
On any of the 3 big manufacturers, Vintage Air/OldAir/HotRod Air, there will be 4 lines going from the engine compartment to the cab (for AC and Heat, just 2 if you just want AC). Those lines have to be routed through the firewall. HotRod Air has some nice bulkheads and www.gottashow.com has some nice SS lines instead of the black rubber lines. But any system will have to have the 4 lines going through the firewall.
67 SWB In Progress, one piece at a time, maybe 3 years I will be finished
adamls is offline   Reply With Quote
Old 05-27-2004, 02:42 PM   #8
busterwivell
I agree with jorgensensc, my Vintage Air system took about 8 hrs total to do, including removal of the old system. I have factory vents and controller. I used the firewall panel from the kit, but I'm sure you can just run the 4 lines thru your smooth firewall if you want to.
Bill - Tucson, AZ
47 Chevrolet 2 dr sedan
56 Chevrolet 210 2 dr sedan
66 Chevrolet Malibu 2 dr 4 speed
71 Chevrolet C30 Longhorn
86 Chevrolet Monte Carlo SS (Sold)
01 Chevrolet Tahoe
IM - BUSTERWIVE@aol.com
busterwivell is offline   Reply With Quote
Old 05-27-2004, 03:31 PM   #9
glock35ipsc
I am aware of that!
I had been told that the Vintage Air system had a protrusion through the firewall other than the bulkhead. My firewall will be flat; I will have welded all holes shut and will be totally smooth after paint. I want to be able to have it already cut for the bulkhead before I paint it. And I really don't want anything else coming through the firewall other than the bulkhead.
Bob
Old 06-04-2004, 05:09 PM   #10
69sixpackbee
Check out airtique. http://www.air-tique.com/That is the system I put in. I went with the "King Kool" one. Bigger evaporator than the "other guys" You can make a smooth firewall with that one. Just run the heater and refrigerant lines to a bulkhead connector assy. on the firewall. You can get a real hi-lustre polish on that bad boy and it will look great! The TXV (expansion valve) is on the evaporator inside the truck so ther is no hardware on the outside. I have some pics if you want to see my install.
Later
69sixpackbee is offline   Reply With Quote
Old 06-04-2004, 07:26 PM   #11
glock35ipsc
Yeah, some pics would be great! Post em here, or send me a PM. Thanks!
Bob
Old 06-04-2004, 07:58 PM   #12
69sixpackbee
Send me an email and I will send them back. I have just a few pics but you can get the idea.
bud.weaver@ectinfo.com
Old 06-05-2004, 11:03 PM   #13
68gmcdually
68gmcdually's Avatar
My kit for my truck is coming from T.B.I. (Terry Brown Industries), they have a kit for our trucks, complete with the "correct" air vents. They have quite a selection of quality products.
James Bellwood
1968 930 Extend-A-Cab Dually 5.7l, 5 speed,
68gmcdually is offline   Reply With Quote
