05-27-2004, 10:11 AM | #1 |
More Cowbell....
Right turns shut my truck off
First a little background info. It's a '69 C-10, inline 6 (250) with a single barrel Rochester (if that's the right spelling). Fuel tank still in the cab. Runs fine, drive it to work everyday. For the past few days, it has developed a syndrome of some sort. If I am turning into a drive way or parking lot, sometimes I will just hold the clutch in and coast into the drive. If the drive happens to be on the RIGHT, the truck will just stall. I can pop the clutch and she will fire right back up and idle just fine. If I am still in gear and off the clutch, say...in the parking garage where EVERY TURN is a right turn, it spits and coughs like crazy, then as soon as I start going straight, it levels out and runs like new. IT DOES NOT DO THIS ON ANY LEFT TURNS. That's what boggles my brain. I replaced the fuel filter (up next to the carb) two days ago, but the issue still exists. Any engine guru-types have an idea what it could be. It only is an issue in town. If it were still on the farm, I wouldn't give it a second thought.
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket |
05-27-2004, 10:21 AM | #2 |
Gotta Startem Early
This question came up a while back on the board, but dont remember the explanation
67 SWB In Progress, one piece at a time, maybe 3 years I will be finished |
05-27-2004, 10:25 AM | #3 |
join nascar they only turn left
05-27-2004, 10:33 AM | #4 |
More Cowbell....
Or I could go NHRA drag. They go in a straight line. I might could get up to 3rd gear in a quarter mile.
05-27-2004, 10:48 AM | #5 |
or you could do both , then you'd have a dual-purpose vehicle
05-27-2004, 11:04 AM | #6 |
check to make sure you dont have a wire shorting out on right turns
http://rick.nicholson.home.insightbb.com |
05-27-2004, 11:09 AM | #7 |
Thats the Hillbilly way
Make sure your coil isn't loose and grounding out to the air cleaner or something else.
BILL Torrance Calif 90504 Member DUF Club Member Old Farts Club 72 3/4ton Custom Camper BB402/400 trans Dynomax Cerama-coat headers , Hei distributor ,Edelbrock 1411 air,ps,pb,leafsprings ,98 chevy 60/40 seat,S10 shoulder belts tilt,3.54 Dana 60 rear. 16" Eagle wheels with LT265/75 16 tires,Gaylord Lid,H4 headlights with 100W relay conversion. " If I knew I was going to live this long I would have taken better care of myself " Marriage changes passion...suddenly you're in bed with a relative. A GUY'S PRAYER.... Lord, I pray for a nympho with huge boobs who owns a liquor store and likes to fish and hunt and has a Harley .Amen , |
05-27-2004, 11:33 AM | #8 |
More Cowbell....
Any chance it could be water? There is none in the filter, but could some be sitting in the carbs bowl or something? Just a thought?!
05-27-2004, 12:22 PM | #9 |
Any time I suspect water, I just throw a cup of isopryl rubbung alchohol in the tank. It can't hurt, and if there's water it'll clear it up. I throw in a little, once or twice a year anyways.
72 Cheyenne Super 4x4 SWB |
05-27-2004, 01:44 PM | #10 |
I had a Nova that did that on left turns. There was an old tach wire hanging too close to the exhaust & it burned through & grounded out when it swung to the right.
05-27-2004, 04:36 PM | #11 |
Check the coil and the ignition system. Also if you can, tear apart the carb. I've got a rochester that gives me crap all the time. Turns out the choke plate acuator rod get stuck in a lot of models, so try pulling off the choke plate. If that doesn't work, check the distributor and all the electrical stuff in the engine compartment to see if anything is worn, broken, or being manipulated by other pieces of machinery. And again, CHECK THE COIL!
1972 1/2 ton Chevy C10 V-8 350, crate engine, with Flomaster dual exhaust. She's Old Blue the Truckinator (no relation to Arnold ) |
05-27-2004, 04:51 PM | #12 |
More Cowbell....
I'll give all of these suggestions a try this evening. Maybe one will work. I'll update as soon as I check out what you guys posted.
05-27-2004, 09:09 PM | #13 |
I had a 72 C10 307 V8 that after making a right had turn would sputter and die.
IRC it was my fuel pump that went bad.
72 Chev C-10 90% restored (former AZ truck) ... 71 Chev K-20 Cheyenne my vacation crusier... 72 Chev C-10 Now retired and striped after many faithful miles... 72 GMC 1500 Retired to the junk yard after bought new in '71... |
05-28-2004, 12:45 AM | #14 |
Mine did that and i had a tank full of water. Drained and refilled with no more problems.
http://www.picturetrail.com/jwill41 67 1/2 ton GMC short step side 68 1/2 ton Chevy long fleet side 72 1/2 ton Chevy Suburban 99 1/2 ton Chevy Suburban founder (and only member) of the primer/clearcoat club |
05-28-2004, 01:45 AM | #15 |
That engine and that carb try checking float level in the carb its pretty easy.
05-28-2004, 09:11 AM | #16 |
I vote on the float too.
1970 CST/10 402,700R4,3:73 posi,AC,PS,PB,TLT,PW,Buckets with heaters |
05-28-2004, 09:17 AM | #17 |
More Cowbell....
I plan on taking the carb off this weekend and give her a good cleaning out. Getting close to the end of this tank of gas too, so I might also drain it all out and see how much is gas and how much is water. Thanks for all the suggestions folks.
05-28-2004, 11:49 AM | #18 | |
05-28-2004, 05:24 PM | #19 |
Hey putter if you dont have time or the place for taking that carb off and checking i got to tell you its the way easy carb to work on while stiil mounted on the truck 4 screws and a little linkage and your in . just dont smoke and take the keys out so some body doesnt go DO YOU NEED ME TO TURN IT OVER bad deal!!!!!!! Check other things first cause there eyeball and some wrist twisting Good luck
05-29-2004, 02:20 AM | #20 |
I had the wire grounding problem on my 72 i was running a 350 thou turns out the yellow wire that goes to the starter from the points coil was just hanging and hitting the valve cover on left turns.
I bought some water dryer upon the advice from the guy at vatozone still did it finally died all the way so i did a roadside diagnostic and found out no fire so i hotwired it from battery to the hei with a peice of wire and when i got home i noticed the yellow wire welded to the valve cover it looked as if it had been hiting for a long time the valve cover had a little burnt spot . |
