Old 05-27-2004, 07:54 PM   #1
ScottH
ScottH's Avatar
Best sealer for engine gaskets?
Need to change out a timing cover and I was wondering what is the best sealer for this, as well as the oil pan if necessary. Any suggestions would be appreciated.
Thanks.
ScottH is offline   Reply With Quote
Old 05-27-2004, 07:59 PM   #2
rage'nrat638
rage'nrat638's Avatar
air craft sealer ...come's in a little can with a brush,,,,,,
best stuff on the market....and it's cheap....try it you will love it.....
get it at your better auto parts store.....
rage'nrat638 is offline   Reply With Quote
Old 05-27-2004, 08:18 PM   #3
Sweet72
Sweet72's Avatar
I think this is the stuff rage'nrat638 is talking about. Good stuff!
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction.
Sweet72 is offline   Reply With Quote
Old 05-27-2004, 08:39 PM   #4
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
That's what I use or gasgasinch..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 05-28-2004, 10:32 AM   #5
jimfulco
If they don't have that, they may have the Permatex Super 300, which seems to me to be the same thing. Looks the same, smells the same, works the same, etc. Good thing we didn't step in it, huh.
Both clean up easily with alcohol, and are not affected by gas, oil, or coolant.
jimfulco is offline   Reply With Quote
Old 05-28-2004, 11:32 AM   #6
adamls
Gotta Startem Early
adamls's Avatar
We use this stuff on 35 million dollar gas turbines, so it has to be good.
67 SWB In Progress, one piece at a time, maybe 3 years I will be finished
adamls is offline   Reply With Quote
Old 05-28-2004, 12:27 PM   #7
ScottH
ScottH's Avatar
Thanks guys, the info is appreciated.
Old 05-28-2004, 01:07 PM   #8
Jeepster376
Jeepster376's Avatar
I used to use that aviation sealer on everything, Now though I use a spray on copper sealer. Sprays like paint, sets up like contact cement, and it's loaded with copper. It glues your peices in place and makes assembly easy, and cleans off easy if you take it apart again.
72 Cheyenne Super 4x4 SWB
Jeepster376 is offline   Reply With Quote
Old 05-28-2004, 01:19 PM   #9
Injected68LS1
Injected68LS1's Avatar
Go to you local honda dealer and pick up a tube of "Hondabond." Not kidding. This stuff is thick but lays out easily. It's the best there is. We use it on our race engines and they never leak.
1968 Chev SWB with 1998 Corvette LS1
305hp and 320 ftlb to the wheels (stock engine!)
AEM EMS and wideband O2 sensors
Bowtie Overdrive's 700R4, stage 3
Baer 4 wheel discs and 20s
http://iciclelanding.com/aperture?album=2049&view=album
Injected68LS1 is offline   Reply With Quote
Old 05-28-2004, 01:22 PM   #10
Jeepster376
Where can I get more gaskacinch? I loved my gaskacinch, but I can't find it anymore. Does it still come in the same can? I've been hangin on to my old dried up empty can of gaskacinch cause I love the vintage pin up girl label. I need a new can.
Old 05-28-2004, 05:30 PM   #11
tomsC10R
tomsC10R's Avatar
I haven't replaced that many gaskets in my short time. But I've had good results using Permatex High Tack on intake manifolds around the intake ports and Permatex Ultra Black Silicone around the water pasages.
Tom
1968 C10 LWB. 402 BB, Holley MPI, 700R4. 4wheel Hydroboost Disk Brakes.
tomsC10R is offline   Reply With Quote
Old 05-28-2004, 07:36 PM   #12
FRENCHBLUE72
PROJECT 7DEUCE
Jeepster I found mine at the local napa...
MEMBER #6377
Project "7DEUCE"
Old 05-28-2004, 08:03 PM   #13
Jeepster376
Ya, lucky, at my local napa (old timers even) they never heard of the stuff. I did a google search today and found a place to order it from. I ordered a couple cans. The old can I have is left over from when I lived in California, probably picked it up at Ralphs.
Old 05-28-2004, 09:42 PM   #14
motoretro
I believe Edelbrock carries Gasgacinch.
I personally use Yamabond, Very nice to work with. Not a silicone product and goes a long way.
motoretro
motoretro
1972 Chevrolet Custom 10 Lwb
www.esivart.com/ebay/truck.gif
motoretro is offline   Reply With Quote
Old 05-29-2004, 12:59 AM   #15
1972C10
1972C10's Avatar
I just plain high temp orange silocone Or the gray its supposed to be what all the Manufactuers are going to I tryed the gray the other day didnt seem any better than the gray but i havent seen what its like after its hardened.
1972C10 is offline   Reply With Quote
Old 05-29-2004, 01:57 AM   #16
Jeepster376
Ya, but they don't have the same can.
