Old 05-27-2004, 11:28 PM   #1
mustanglx347
found 82 blazer for $800 wondering what to look for
thought it was a 77 but turns out it's an '82, both 10 bolts front and rear. a little rust on the driver side rocker. it was a diesel, still has the radiator, but the motor is a 350. It runs and drives. and supposedly the 4X4 works...will see tomorrow. is there anything else i need to look for. It has 2 tops.
'71 Chevy stepside
'50 Chevy 5 window
'82 K5 Blazer
'90 Mustang-stroked and sprayed
'95 Nissan 300 ZX
'04 Jeep Grand Cherokee
mustanglx347 is offline   Reply With Quote
Old 05-28-2004, 02:08 PM   #2
mustanglx347
well, I bought it and it is a bucket , but I think with some TLC it will be a good trail rig.
'71 Chevy stepside
'50 Chevy 5 window
'82 K5 Blazer
'95 Nissan 300 ZX
Old 05-31-2004, 09:01 PM   #3
Mike Martin
I have had an '82 since '86. Be aware that the gaskets between the removable roof and the body/fixed roof can wear out and cause leaks that can ruin your floorpans. The windshield can also leak causing rust problems. You may have already found this out. I was going to replace the floorpans in mine but patched them with a product call MarineTex and then painted with POR15. I have all of the floorpans (new) in case you are someone else would be interested in them. Thanks.
Mike
Mike Martin is offline   Reply With Quote
