intake leaking oil
on the top of my edelbrock torker intake the middle bolts are leaking oil .its the 2 middle bolts on both sides.should there be washers there o-rings.there are just bolt there now. any suggestions
springfield illinois 2003 custom (harley)built from scratch 68 swb |
Gotta Startem Early
I dont think there should be any washers or o-rings. If the bolts are leaking then that means the oil is leaking by the intake gaskets. That oil is also probably getting into the intake passages and cylinders. Is you truck smoking, burning, losing oil.
67 SWB In Progress, one piece at a time, maybe 3 years I will be finished |
it burns oil when you hammer the gas.i belive its running off the intake onto the exhaust though,so its not technicly(sp) burning oil.its just leaking on the top of the intake
Gotta Startem Early
Thats the thing, the only way for oil to get to those bolt holes, is to go past the intake gasket. If it is leaking past the gasket at the bolts, then there is a chance it is leaking into the chambers. You might have the intake checked for flatness. Replace the gaskets with some silicone, should fix it up.
ok ill give it a shot thanks again
it's a very common problem , when the intake was installed those bolts should of been treated with thread sealer just remove the bolts clean them up put thread sealer on them retorque the manifold and you'll be good to go,it's doubtfull there's any problems with the intake gaskets
PROJECT 7DEUCE
![]() Join Date: Dec 2002
Try some silicone on the 4 middle intake bolt's....
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
#8 | |
Next project: 1970 K10
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE |
Junior Member
Had the same trouble with a with an Edelbrock 2101 intake. I am looking hard at some of the aftermarket bolt sets because some of them are shouldered bolts and maybe I won't cringe when tightning them down. Let us know what works cause i'll bet we aren't the only two with the problem.
72 C10 10 yr.daily driver 68 C10 18 yr.money pit 72 Nova all original 99 H.D. Heritage[sanity check] 71 VW topless bug[summer fun] "When I have the money, I don't have the time ; when I have the time, I don't have the money. |
I ran some mr gasket 1/2 head intake bolts with shouldered heads still leaked when i had the intake off put some silly on the middle 4 hasnt leaked since..
On my 85 i used exhaust manifold bolts off a 454 85 model used them as sbc intake bolts there shouldered also but 9/16 head some of the 454 3/4 tons had header type manifolds so maybe you can buy bolts for that app cheaper than aftermarket kits. |
i've found silicone does little to solve the problem but using a high quality automotive thread sealer with teflon in it works every time
Contact Edelbrock for the proper torque sequence and their recomendations on the issue you have....they are very helpful.
1970 Chev CST 2003 Harley Fatboy 1975 Chevrolet Step Van 1956 Chev Bel Air 1977 Blazer 2WD For Sale $3000.00 1978 Blazer 2WD For Sale $7000.00 1978 Silverado 2005 Monte Carlo |
#13 |
well this has been my daily driver for about 4 months.but i bought a 2000 chevy truck today.so i will be able to tear into it now.i also have to fix all the crap that happens when you turn them into daily drivers.not bad just some paint chips,and dumbasses with automatic door dingers.
