Old 05-28-2004, 12:08 PM   #1
Chevelle454
Chevelle454's Avatar
350 rods in a 305...
Can 350 rods be used in a 305? I am going to rebuild my '84 305 and I know that 305's have relatively weak bottom ends. Could I use the 350 crank and rods from a 1987 350 TPI(out of a camaro)? Are the rods the same size and the crank the same size? Will it all just bolt right in with the standard bearings?
Thanks...
1972 C10
1972 C20
Chevelle454 is offline   Reply With Quote
Old 05-28-2004, 12:28 PM   #2
Warrens69GMC
Warrens69GMC's Avatar
info
Yes it will all bolt in and work, but you will need to have it balanced. The 305 has a weak bottom end due to only being a 2 bolt block.You can convert the 305 to a 4bolt with the 350 caps and align hone. Or, even better, splayed caps make it MUCH beefier. Use ARP bolts on the rods & mains and it is as stong if not more, than a stock 350.
warrens69gmc
Old 05-28-2004, 12:37 PM   #3
motoretro
The 305 crank carries same casting number as a 350 although it is balanced differently to accomodate the lighter pistons on a 305. The 350 rods are same length and journal sizes are the same and should not be a problem. If you install the 350 parts, you will have to have quite a bit of material removed from crank to balance out with 305 pistons. When you pull your pan, look at the notch cut into the 305 crank's throws. You should be able to lay a straight edge in this notch from front to rear. Thats the amount of material that has to be removed. Bearing sizes are same. 350 crank drops in...I personally feel the bottom end is fine with whatever hp mods you may make to the 305
Good luck
motoretro
motoretro
1972 Chevrolet Custom 10 Lwb
www.esivart.com/ebay/truck.gif
motoretro is offline   Reply With Quote
Old 05-29-2004, 02:36 AM   #4
1972C10
1972C10's Avatar
That 2 bolt 4 bolt stuff is retarded .
The way they are balanced the crank that is.. is by the holes being drilled depper in 305s Ive ran 305 crank rods in 350s before and not getting balanced without probs but never the other way ..
I tore down a 305 out of a boat awhile back It had "X" rods there currently in my 3/4 ton
Depending on what year 305 you have the later model ones had "X" rods Or so my engine builder says I tore down a 305 out of an 86 gmc the other day it had x rods but two were trashed due to cam breaking ,
And if you were to get 350 4 bolt caps and get them aling bored on a 305 that would be the lamest thing i have ever heard you could get a 350 40 bolt core for what that would cost.
And if you decide to put some ARP bolts in it I have a set friend bought a few years ago he ended up getting a windage tray And it required studs Thus never used them so i wound up with them .
1972C10 is offline   Reply With Quote
