Old 05-28-2004, 02:12 PM   #1
bucket
bucket's Avatar
need turn signal help.....
i replaced my upper bearing, turn signal assembly and cancelling cam last night. Everything works except the cancelling function. Any tips? Also, would anyone happen to have an exploded diagram of the column assembly for a 67 non-tilt?
bucket is offline   Reply With Quote
Old 05-29-2004, 12:22 AM   #2
'68OrangeSunshine
'68OrangeSunshine's Avatar
Did you remember the little springs? Also the position of the cancelling cam is critical. The "bump" on the cam has to be in position to nudge the spring out -- killing the turn signal --as the wheel turns back. There' s one for each side.
'68OrangeSunshine is online now   Reply With Quote
Old 06-01-2004, 10:24 AM   #3
bucket
bucket's Avatar
Talking
Thanks. Got it figured out. the vertical metal spring on the end that indexes the signal on and off was set to stiff. retentioned it and the cam lobes and little springs can now overcome it.
