05-28-2004, 05:34 PM | #1 |
USA love it OR leave it!
4" Lift Pics please....
I requested pics in another thread but I thought it might be easier to make it its own. So if you guys could show me what you got that would be sweet.
THANKS!
Later, CHEVY_FOREVER |
05-28-2004, 07:32 PM | #2 |
4" lift
Does a blazer count?
http://www.imagestation.com/picture/...6/f89f541f.jpg 4" spring lift w/33's - E/Z ride system...you could live with it on a driver. Last edited by vtblazer; 05-28-2004 at 08:54 PM. |
05-28-2004, 07:50 PM | #3 |
Click on my link, I have the 4" rough country lift. I wouldn't recomend it though, I think it's named rough country for a reason.
72 Cheyenne Super 4x4 SWB |
05-28-2004, 07:54 PM | #4 |
user # 2756
Click on link in sig. the green truck has 4" lift and bald 35s.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs 1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX 1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears 1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now..... 1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone. 1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed. 1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm |
05-28-2004, 11:49 PM | #5 |
Thanks guys....please keep em coming!
05-28-2004, 11:51 PM | #6 |
Dang I like the 4" and the 35's...maybe i should order that size... any rub?
05-29-2004, 09:11 AM | #7 |
4''
[IMG]http://[/IMG] hope this works 4X4 has 4 '' lift
C/10 John N.J. |
05-29-2004, 09:15 AM | #8 |
Post Whore
Here is my 69 K20 when I put on it's first lift, a 4" Tuff Country lift with a shackle flip in the rear. 35" SSR's. Now it has 11" of lift
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
05-29-2004, 10:35 AM | #9 |
Basically 4"
Newer chassis and a body lift was used to get the cab up off the TC. It probably could have been a inch or two lower but the tires would have been a lot closer. The rear fenders will rub when twisted.
05-29-2004, 10:18 PM | #10 |
user # 2756
Added some pics to the link in my sig.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs 1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX 1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears 1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now..... 1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone. 1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed. 1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm Last edited by JIMs70GMC; 06-02-2004 at 06:36 AM. |
05-30-2004, 07:55 AM | #11 |
Red Rocket
4" SkyJacker.
If you need any info on doing this right I just finished this one and it is not as easy as everyone makes it out to be. Do not buy the raised steering arm. Use the original and make your adjustable drag link shorter. This way you don't loose steering |
05-30-2004, 08:47 AM | #12 |
4" lift and 33" parnelli jones.........
71 chevy 4x4 ,np205 transfer case, 3 speed tranny, sjs 283, 4in suspension lift, and 71 hugger orange paint,33x12.5 parnelli jones on 15x10 m/t classicII, cowl hood,new bed painted, linex liner. Truck has been completed since 2005.... 2003 Chevy Avalanche Z71, on 6in super lift w/ 35in tires RNG4x4 aka the "Redneck Roller" words to live by "If it fits, it fits" "friends help you move, real friends help you move bodies..." Sponsored by "Kick Ass Kustom" |
05-31-2004, 12:17 PM | #13 |
Certified Chevy Man
3 things:
1. 35's will rub with a 4" lift if you don't cut the fenders and actually wheel the truck. 2. If you don't put a raised steering arm, or a dropped drag link or drop pitman arm on, you will not be able to turn if you wheel the truck. When the driver's side flexes down all the way, the drag link is at such a steep angle that it essentially leaves you with you steering. Also I put my raised steering arm on the day after I did the original 4" lift on my suburban. I took it out after I got the springs on and when the driver's side flexed up and I turned to the right, the stock steering arm hit and dented the cylinder on my new Rancho 9000X shock 3. I don't know what's so hard about putting on 4 leaf springs(or 2 leaf springs and 2 blocks), extended brake lines or brake line relocation brackets, 4 shocks, and something to correct the steering. I've put 4" and 6" lifts on many of these trucks before without a problem in a matter of a few hours. Just thought I'd throw that information out.
68 Chevy CST (327,TH400) 3/5 drop lots of fun stuff 71 Suburban 4x4 (350,TH350) 7" lift 37's, D44/14 bolt and other sorts of goodies, lockers front and rear, flexes 40", 895 RTI score Check out my web site!!! http://www.geocities.com/cst68chevy/ |
06-01-2004, 04:55 PM | #14 |
Again THANK YOU to those who posted some very nice pics of their rides. It has helped me greatly. I don't get tired of looking at them so please if you have please post them.
Also, is there a way to make the rear wheels sit as wide as the front? Spacers or something? I am putting on 33" on ralley wheels, any ideas? Thanks,
Later, CHEVY_FOREVER Last edited by CHEVY_FOREVER; 06-01-2004 at 04:59 PM. |
06-01-2004, 10:56 PM | #15 |
Recovering 67-72 Addict
4" Superlift, 33" BFG's
68 Short Fleet 4x4; 427; BTO Level 3 700R4; NP205; Dana 60 front and rear; 4" lift with 35's; Disc brakes; AGR variable ratio steering; factory bucket seats; factory tach and tilt. "Friends call me cruzer cuz I like fast cars and fast women" |
