Old 05-28-2004, 06:57 PM   #1
cableguy0
converting 65 c/20 to power disk 71/72
converting 65 c/20 to power disk using 71/72 parts can it be done as far as just dropping the crossmember out of the 71/72 and bolting it into the 65. are the frames the same in the front
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 05-29-2004, 01:20 AM   #2
cableguy0
someone has to know ttt
Old 05-29-2004, 10:51 AM   #3
frogsmakr
frogsmakr's Avatar
Thumbs up
yep-2wd that is....i have done spindles/lower a frames on a 65 gmc, and the whole crossmember on a 64 gmc.
frogsmakr is offline   Reply With Quote
Old 05-29-2004, 11:05 AM   #4
lolife99
67-72 parts collector,…
lolife99's Avatar
Check Early Classic Enterprises, they have a conversion spindle (c20 to c10) that will let you keep your crossmember, a-arms, etc. Just swap spindles and use half ton rotors and calipers. Not nearly as much work.
Old 05-29-2004, 07:06 PM   #5
cableguy0
thanks guys in the process the truck is going to be converted to 5 lug so the spindles might be the way to go i just wanted to make sure that everything was the same
Old 05-29-2004, 11:12 PM   #6
highboy_04
highboy_04's Avatar
if you dont already have the stuff i've got all you need out of a '72 chevy. just letting you know in case you need it.
'67 c10 350/th350
highboy_04 is offline   Reply With Quote
