Old 05-28-2004, 10:27 PM   #1
NuBomb
NuBomb's Avatar
Got carb, now what?
I'm installing a carter carburator (Just like edelbrock) I got from board member 70c10 (Great guy to deal with btw) and I've just got a few questions. My old Holly was manual choke so I know I've got to run a wire from fuseblock to choke that is hot with key, but what guage wire and do I need to put an inline fuse with it. Also, what about linkage connection. My throttle cable, and detent cable, and springs don't look to smooth so far. Any suggestions?
Thanks, Jeremy.
Jeremy (NUBOMB)
72K5 CST 350/350/205
1951 Chevy 1/2 ton
North Georgia Group
"... And the first rule to being a man is you gotta spend your life doing crap you don't wanna do." Red Forman.
NuBomb is offline   Reply With Quote
Old 05-28-2004, 11:30 PM   #2
Sweet72
Sweet72's Avatar
Use 16 ga. red wire from a switched source on the fuse block. I think a 5A inline fuse would be alright for this application.
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction.
Sweet72 is offline   Reply With Quote
Old 05-29-2004, 01:48 AM   #3
1972C10
1972C10's Avatar
The linkage is in the same spot as a holley i switched back and forth a few times back in the day the only swap that ran into any probs was q-jet to edelbrock or holley .
1972C10 is offline   Reply With Quote
Old 05-29-2004, 10:47 AM   #4
70c10
67-72 Addict!
70c10's Avatar
Wow Jeremy, that got there faster than I thought!. As far as the linkage goes, my truck has the rod style linkage and I had no problems going from that carb to the Demon. There should be lots of pics on here with guys running Edelbrock's with the cable setup like yours. Also for the manual that you can print out go here: www.edelbrock.com and look for the square bore EPS manual. Keep us posted!
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 05-29-2004, 03:10 PM   #5
guyryan100
guyryan100's Avatar
Another Georgian! I'm not much help on this one, but nice to see GA members.
guyryan100 is offline   Reply With Quote
