Got Horsepower?
driveline slack
when ever i accelerate or let of the gas or drive slow through a bumpy parking lot there is a clunk in the drive line. is this caused by worn out u-joints?
2001 Dodge 2500 Cummins, 4 inch lift, 35" Toyo MT's on Ultra wheels, P-Pump Conversion, AFE intake, Fass, 5 inch exhaust, Pyro,Boost,and Fuel pressure guages, and a whole bunch of other stuff "The Money Pit" SOLD-71 Chevy C10 long bed- 2/4 drop-- 350,th400, Edelbrock performer RPM intake,Edelbrock 600 CFM carb,Crower 240 cam,port and polish,Dynomax headers,HEI ignition,dual 2.5 inch exhaust with Flowmaster 50 series mufflers |
Easy to figure out. Block the weels and put it in neutral. Climb underneath and wiggle stuff. Twist the shaft, move it up and down, side to side. You will be able to see and hear what is worn out.
Andy,Phx AZ '67 C-10 (Ahhh, done at last. Well there is that disk front end I want to put in and...) "23 C-Cab-sold '48 Ford 8N tractor(still working) '67 Scout(Now on the road) '70 MG B.-sold |
Got Horsepower?
thanks! i'll crawl under it and check it out in the morning
I had an old 4 speed 3/4 doing exactly what your describing was a combo or u joints and worn out gears .
Got Horsepower?
it knocks when i go over rough roads or bumps. how much should i be able to turn the shaft when the tranny(th350) is in neutral and the parking break is on?
Well there is no how much Some you can turn a good ways some are very tight all due to wear i would say if it moves more than just a tad its loose or worn try turning the yoke on the rearend to see if its the ring and pinion If its just a worn ring and pinion it will last for no telling how long I have seen them with alot of slack or howling forever and not go out.
The thing to look for is movement in your U-joints where the little rubber seals are. None is acceptable. Some rotation of the pinion, or tailshaft yokes is normal.
72 Cheyenne Super 4x4 SWB |
Got Horsepower?
i'm pretty sure that is is the gears so how much should i worry about it? will the gear teeth eventually break off?
