Got Horsepower?
no dash lights
none of the lights in my dash are working and the coil in the light switch looks alright what else could be causing the problem
2001 Dodge 2500 Cummins, 4 inch lift, 35" Toyo MT's on Ultra wheels, P-Pump Conversion, AFE intake, Fass, 5 inch exhaust, Pyro,Boost,and Fuel pressure guages, and a whole bunch of other stuff "The Money Pit" SOLD-71 Chevy C10 long bed- 2/4 drop-- 350,th400, Edelbrock performer RPM intake,Edelbrock 600 CFM carb,Crower 240 cam,port and polish,Dynomax headers,HEI ignition,dual 2.5 inch exhaust with Flowmaster 50 series mufflers |
Inline 69
did they just "stop" working or did you repair/replace something and now they dont work? do your parking lights work?
generally a fuse blown, have you checked for a ground problem?
1970 Chev CST 2003 Harley Fatboy 1975 Chevrolet Step Van 1956 Chev Bel Air 1977 Blazer 2WD For Sale $3000.00 1978 Blazer 2WD For Sale $7000.00 1978 Silverado 2005 Monte Carlo |
Got Horsepower?
the headlights and parking lights work but there are no dash lights. they only worked on 1 position before. after i took the cluster apart to put in a autometer volt guage and put it back in the truck they didn't work so i changed the switch and they still dont work but i can turn on the light in the cab. it would be kind of nice to be able to see my guages at night. did something get grounded out or ????
![]() Join Date: Mar 2003
Get a test light. Pull the headlamp switch to the first position. Test the fuse for tail lamps, if good proceed to the dash, if not check the headlamp switch, for power coming out to the fuse. If you have power, go to the dash and see if it makes it that far, if so check the bulbs, if the bulbs are ok check the ground.
i love summertime
i have the same problem, i know i have 1 or more bulbs burnt out, could this be why?
1967 shortbox stepside Chevy, 365 hp 327, th400. GLOVE BOX LIGHTS FORSALE, click link for info http://67-72chevytrucks.com/vboard/s...d.php?t=273724 |
#7 | |
Inline 69
Got Horsepower?
what is the black wire for? the only wires i saw connected to the guages was the main plug.
the black wire is your ground. it goes behind one of the screws and it makes the lights work chances are you didnt notice it and didnt put it back on...
70 longbed 496/th400/Ford 9" |
Blazerless:-(
In the pic posted by jef5150 where does the other end of that black wire go to...???
Does it reattach back to a screw on the cluster, or come from somewhere in the truck. Excuse the dumb question, but I know nothing about wiring and I am redoing my dash cluster today to put in a tach conversion kit. I didn't have dash lights before, and I would LOVE to have them now. :-) Diane |
i love summertime
i figured my problem out, it was the highbeam switch on the floor
