Old 05-29-2004, 01:05 PM   #1
nosto
Flamin' Bass
nosto's Avatar
Steering wheel wobble - fix?
I have a '67 C-10 with PS and Grant steering wheel installed by the PO. You can move the steering wheel side to side/ up to down on the stock (non-tilt) column. The wheel is tight on the shaft, but it looks like the shaft is sloppy in the column.
I looked on a few parts suppliers on the board, but only found replacement parts for the tilt columns. Anyone know where I can get the (bushing/bearing?) for the upper part of the column; assuming that's what the problem is?
Thanks,
Rick Olson /nosto/
Galloway, NJ
Pics : http://community.webshots.com/user/nosto53
1972 Triumph TR6 - full resto, now with a Toyota 5-speed
1975 F**D F-100 - rusty, but reliable
1982 HD XLH-1000
1967 C-10, shortstep, 350/M21 4spd, nitrogen tank fills fast bags on 4 corners, Toyo 255/45X20s on American Eagle 221 20X8s, shaved locks and handles, antenna, fuel filler, tiny C-notch, rear fuel tank, long headers, Edelbrock, worn 600 Holley, Checkmate flush hard cover, rear pan, custom LED taillights - painted it, too! But don't like it so I'm gonna do it again!!
nosto is offline   Reply With Quote
Old 05-29-2004, 01:14 PM   #2
MACKL
Almost done!
MACKL's Avatar
I've got one but the shipping would be more than you could purchase one locally. If you can not find one, pm me and I give you one for the cost of UPS. But you should be able to find one...Kelly
The 1970 SWB Project
Removed 6cyl manual trans, manual everything
V8-350
Auto/PS/PDB
Blazer Fuel Tank
Behind the Marker Light Fuel Fill
MACKL is offline   Reply With Quote
Old 05-29-2004, 01:15 PM   #3
Jeepster376
Jeepster376's Avatar
Check the spring at the bottom end of your column, there is a spring about an inch long that tensions the column shaft. Yours may be weak or broken.
72 Cheyenne Super 4x4 SWB
Jeepster376 is offline   Reply With Quote
Old 05-29-2004, 09:07 PM   #4
70 net440
Junior Member
70 net440's Avatar
You can get the bearing from your local Chevy dealer. I don't have the part number, we tossed the bag when we fixed the kid's column.
63 C10
70 Coronet R/T
67 C10
70 Dart Swinger
71 K10
70 net440 is offline   Reply With Quote
Old 05-29-2004, 10:03 PM   #5
69 Short Fleet
I replaced the upper steering colum bearing on mine for the same reason, and it made no difference at all with the side to side & up and down play. Interesting what Jeepster376 says about the broken or tired spring at the bottom of the column I'll have to look into mine as well, (great tip). Doug
69 Short Fleet is offline   Reply With Quote
