Old 05-29-2004, 01:49 PM   #1
dubie
dubie's Avatar
where does this wire go??
I am at the shop right now and this is the last wire to hook up, now where does it go to? Does it ground to the rad support or does it feed back to the battery? And if it goes to the battery, which terminal?
My name's Tim and I'm a truckaholic
My 56 Chevy shop truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=562795
dubie is offline   Reply With Quote
Old 05-29-2004, 01:52 PM   #2
dubie
dubie's Avatar
a lighter pic. It's the red wire I am wondering about
Old 05-29-2004, 01:53 PM   #3
cdowns
cdowns's Avatar
positive battery
Old 05-29-2004, 01:54 PM   #4
Jeepster376
Jeepster376's Avatar
That is your alternator feed to the battery. + side.
72 Cheyenne Super 4x4 SWB
Jeepster376 is offline   Reply With Quote
Old 05-29-2004, 02:38 PM   #5
dubie
dubie's Avatar
You guys are the best...1 more question
Fuel lines.
Why do I have 2 lines coming to the front of the frame and only 1 port to hook them up to on the fuel pump?
This is a pic of my 72 parts truck that has the same set up
Old 05-29-2004, 02:48 PM   #6
cdowns
cdowns's Avatar
second line is the vapor line to return vapors from those stupip charcoal canister thinds
Old 05-29-2004, 03:30 PM   #7
Slams_58
Can we just cap it?
Slams_58 is offline   Reply With Quote
Old 05-29-2004, 03:46 PM   #8
canadianchevy72
Ah HA! I know found the reason my alternator isnt charging!
1972 Chevy C/10
350/200r4
canadianchevy72 is offline   Reply With Quote
Old 05-29-2004, 03:55 PM   #9
jorgensensc
jorgensensc's Avatar
Actually the red wire goe to the pos. battery cable. that thing it connects to is the power junction box. It runs a lot of different things. I'm not sure, but I think the alternator might connect back through there also.
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
Old 05-29-2004, 05:32 PM   #10
CPNE
Resident Curmudgeon
CPNE's Avatar
Originally Posted by Slams_58
Can we just cap it?
Yes. The 3/8 line should go to your fuel pump. The other should be 5/16th and can be deleted, assuming you don't have a return line from fuel pump. After 70 or so, a return line to the tank was used on 1/2 tons, helped with vapor lock and emmissions stuff.
Currently on or near the homestead:
67 Chevy SWB 2WD stepside 350/3 on tree (Pat's)
67 GMC SWB 2WD Fleet 402/auto (Brian's under construction)
67 Chevy 3/4 ton 2WD 402/auto (Business Hauler)
67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC)
68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC)
70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC)
71 Chevy SWB stepside (Crushed by tree - parts donor)
72 Chevy 3/4 ton 4WD (Parts donor)
72 Chevy 3/4 ton 4WD Suburban (Parts Donor)
72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC)
81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler)
82 Camaro Z/28 355/Super T-10 (Pat's toy)
93 Caprice 9C1 (Brian's Cop Car)
02 Toyota Camry (Reliable but a souless steel and plastic hulk)
2011 2SS RS Camaro M6 Factory Hurst Shifter
Maybe I need to sell some of this crap
Yet another Bozo with a sawz-all
CPNE is offline   Reply With Quote
Old 05-29-2004, 06:24 PM   #11
Russell
Professional Grade
Russell's Avatar
I've got my return line plugged off as well, no problems to speak of, and I have dual tanks now!
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 06-07-2004, 08:17 AM   #12
71-longbed
Its Magically Delicious
71-longbed's Avatar
the red wire that goes to the juntion box ... does it have a fuse inline... i know they call it a fuseable link .. but i just wanted to be sure .. im planning on making my own positive battery cable .. just making sure i wont fry something by not having a fuse between the + terminal and the juntion box .... anyone??
thanks
71 C10 LWB
350sbc -TH350
12 bolt 3.42 Posi
Of all my favorite things to do, The utmost is to have a brew.
My love grows for my foamy friend, with each thirst-quenching elbow bend.
Beer so frosty, smooth, and cold it's paradise pure liquid gold.
Yes beer means many things to me that's all for now cus I gotta pee.
71-longbed is offline   Reply With Quote
Old 08-21-2004, 03:07 AM   #13
kbs71
71 rustless in texas
kbs71's Avatar
Go to www.madelectric.com and check out his explanation of the older GM wiring harnesses.
kbs71 is offline   Reply With Quote
Old 08-21-2004, 03:46 AM   #14
71-longbed
71-longbed's Avatar
link doesn't work
71 C10 LWB
350sbc -TH350
12 bolt 3.42 Posi
Old 08-21-2004, 04:03 AM   #15
jimfulco
try www.madelectrical.com
jimfulco is offline   Reply With Quote
Old 08-21-2004, 08:01 AM   #16
Huck
Huck's Avatar
re. fuel vent line. If you just plug this cannister line solid on a 72, you may have created a venting problem as these trucks were vented thru this line. So what you might want to do is route it upward away from exhaust, spark potential, etc and put a vent cap on the hose so as to allow the tank to breathe. Plugged, you will probably get a huge hiss when you open your correct 72 tank cap. Another option is to plug the line solid but use an early tank cap which is vented. YOu then sometimes may get gas vapors from the cap so ---your call just want to make sure you don't fix one problem and create another--been there done that all too often!! Huck
Huck is offline   Reply With Quote
Old 08-21-2004, 08:15 AM   #17
Huck
Huck's Avatar
GREAT SITE - a sure favorite from now on!!
Old 08-21-2004, 08:19 AM   #18
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Dubie, throw that wire away and replace it with a fusible link. Someone has done away with the fusible link on your truck. It's what protects that circuit.
Running no fusible link is like wrapping all your fuses with aluminum foil. They are too important to negate them.
Old 08-21-2004, 09:46 AM   #19
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
"THAT" wire, if allowed to ground against anything, will reduce the wiring harness to garbage. I can testify to that event, in that the alternator end got against my headers and the whole harness had a soft "glow" about 6AM one morning. Also, the engine will die, when the wire is grounded. If a fusible link is appropriate, go for it. Whatever came in my NEW harness, is what I installed. The new harness also had clips that route the harness out of harms way and restrain it to prevent the "uh-oh" that fried my harness and made for a bad day.
Make sure that you clean, wire brush, or whatever is handy, the terminal block that the wires attach to. Also, make sure that the insulator is good. GM doesn't have any of them available, to my knowledge, nor did I find a replacement part.
I didn't have a pair of wire cutters (diagonal cutters, aka "dikes") handy, so grabbing a glowing wire is NOT recommended with bare hands. Did that. But, saved the truck in the process, so everything has a price.
Member Nr. 2770
