Old 05-29-2004, 07:21 PM   #1
Slams_58
It's turning over!!!! Progress!!!
The new engine is now turning over!!! But the fitting from the fuel pump that connects the fuel line to the carb buggered up and starting pissing fuel so it wouldn't hold enough fuel pressure. It would fill the filter and then start pissing. SO we went and got a new fitting and are headed back to the shop in a few minutes to see if we can get it to run tonight. We'll keep you updated
Slams_58 is offline   Reply With Quote
Old 05-29-2004, 07:46 PM   #2
BOSS
Just here to help
BOSS's Avatar
bet you two are excited to hear it run.Let us know what it sounds like.
Support our site
Norwood Survivor
BOSS is offline   Reply With Quote
Old 05-29-2004, 08:11 PM   #3
dubie
dubie's Avatar
Does anyone have any tips on firing this pig?? It keeps turning over but it just won't seem to fire. The fuel filter doesn't look to be full, so it seems like it isn't sucking gas into the carb. I had a small flame shoot out of the carb already But that was because I dumped a small amount of fuel in there thinking it would fire up. I could really use some help on this guys
My name's Tim and I'm a truckaholic
My 56 Chevy shop truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=562795
dubie is offline   Reply With Quote
Old 05-29-2004, 08:17 PM   #4
Randy70C-10
Randy70C-10's Avatar
Shouldn't have any fire shooting out of the carb, try advancing your timing. If this doesn't work, you might be 180 out.
Randy70C-10 is offline   Reply With Quote
Old 05-29-2004, 08:35 PM   #5
BOSS
Just here to help
BOSS's Avatar
It does sound like it would be 180 off to me also.
Support our site
Norwood Survivor
Old 05-29-2004, 08:43 PM   #6
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Any luck????? Hope if will fire for ya...
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 05-29-2004, 09:14 PM   #7
dubie
dubie's Avatar
gonna try turning it 180 degrees to see if the timing was off now. I'll update you guys in about 15 minutes
Old 05-29-2004, 09:47 PM   #8
racedvl
racedvl's Avatar
It's been more than 15 min. . . .
racedvl is offline   Reply With Quote
Old 05-29-2004, 09:49 PM   #9
dubie
dubie's Avatar
well we managed to get a flame shooting out the ramhorns! Does that count as progress?
Old 05-29-2004, 09:51 PM   #10
FRENCHBLUE72
PROJECT 7DEUCE
yep!!!!! kick the tire's and lite the fire's....
MEMBER #6377
Project "7DEUCE"
Old 05-29-2004, 10:03 PM   #11
dubie
dubie's Avatar
I am running out of thigns to try here. We have been PM'ing with Randy for the past hour or so and have tried just about everything to get her to fire. Just takin a breather and will head back to it in 5
Old 05-29-2004, 10:13 PM   #12
Canadian694x4
Born To Lose Club
Canadian694x4's Avatar
Location: Calgary, Alberta/Oxenden, Ontario, Great White North
...Dubie I'm routin' for you and the Flames tonight!
Brian Smith - "Born To Lose"
1969 Chevrolet K10 LWB Fleetside - Proud Owner For 22 Yrs - 1 of 208 Built & Sold In Canada!- 283 V8/350TH/NP208, 2" All Spring Lift, 32" Good Year MT/R's.
1972 GMC K2500 Custom LWB Fleetside - Proud Owner For 3 Yrs - 1 of 571 Built & Sold In Canada! - 350 V8/SM465/NP205, 4” Rough Country Lift, 33” Interco TSL Thornbirds
2007.5 GMC Sierra SLE 2500HD 4x4 - Proud Owner For 17 Yrs- 6.6L V8 Duramax Diesel/Allison 1000, 2" Lift, 33" Mickey Thompson MTZ's.
2008 Yamaha Raptor 700r - Proud Owner For 15 Yrs - ITP Mud Lites.
2015 John Deere 1025R - Proud Owner For 8 Yrs - 24HP Diesel/H120/54D/260B/SB1154.
Canadian694x4 is offline   Reply With Quote
Old 05-29-2004, 10:34 PM   #13
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
Well, if things start getting too frustrating, try it from the beginning again......
Check the plug wires again to be sure the firing order is right,
pull the #1 plug and get back to TDC,
check the distributor setting again
If yer blowing fire, there is a timing/firing order issue somewhere. It could be 180 plus one tooth out, or it could have been right on and just one tooth out. Better to start from square one than it is to pull the wrench out of the windshield.
Good luck!!
P.S. - I've never put a wrench through a windshield.
Well, at least it wasn't my windshield!
But that's another thread!
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 05-30-2004, 11:36 AM   #14
Yukon Jack
Post Whore
Yukon Jack's Avatar
Any luck? I'm keeping my fingers crossed for you both!
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 05-30-2004, 12:01 PM   #15
dubie
dubie's Avatar
IT RAN IT RAN!!!!! We're not 100% there yet but it ran and holy hell is it LOUD!!! I"m like a giddy lil school girl right now!! ( which is ok cause this is Shawna posting! )
Old 05-30-2004, 12:08 PM   #16
glock35ipsc
Originally Posted by dubie
IT RAN IT RAN!!!!!
Awesome!! So what was the final verdict as to why it wouldn't start?
Bob
Old 05-30-2004, 12:11 PM   #17
dubie
dubie's Avatar
I forgot to turn the rotor to face #1 plug!! I KNEW it was something simple I was missing.
Now can anyone tell me where I hook my electric choke up to?? It's running but them stall out becuase the choke closes right off
Old 05-30-2004, 12:16 PM   #18
glock35ipsc
Usually there are two terminals on the choke; a power and a ground. Ground the ground , and for power, run a fused wire to an ignition-on circuit. There are a couple of ignition-on terminals on the fuse block. A 5 or 7 amp fuse will be sufficient. Basically, you only want power to the choke when the key is on.
Bob
Old 05-30-2004, 12:25 PM   #19
dubie
dubie's Avatar
we only have one terminal.... no ground....
Old 05-30-2004, 12:30 PM   #20
junkyardjohn
junkyardjohn's Avatar
DUBIE ... WHAT KIND OF CARB IS IT??? I GET POWER FROM THE HOT WIRE THAT FEEDS MY HEI. JOHN
junkyardjohn
69 1 TON TOW TRUCK //
84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES//
LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS)
DON'T RENT U-HAUL
ALWAYS TELL THE TRUTH
IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST
junkyardjohn is offline   Reply With Quote
Old 05-30-2004, 12:38 PM   #21
dubie
dubie's Avatar
I gave it power from an unufused ingnition next to the HEI. it's a Rochester 4 barrel.
Old 05-30-2004, 01:38 PM   #22
Canadian694x4
Born To Lose Club
Wooo Whooo!!!!
Congrats on getting her running!
Old 05-30-2004, 04:57 PM   #23
TODDS 72
Not the nightly winner
TODDS 72's Avatar
very cool guys,bet your both pretty happy eh?.........lol
72C10SWB BLUE 350/350
86K10LWB BLUE 5.7 700r4 7.5' fisher plow
93S10XCAB4X4 BLUE 4.3 4L60e
69gmc c10 v8 3 on the tree yellow 72k10 swb 350 3 on the tree green
86k15 swb5.0L 4spd brown
TODDS 72 is offline   Reply With Quote
Old 05-30-2004, 05:02 PM   #24
Randy70C-10
Don't forget to tighten the valves back down.
Old 05-30-2004, 07:10 PM   #25
racedvl
racedvl's Avatar
Did you break in the cam?
