Blue 67
![]() Join Date: Apr 2004
What is this cable?
I would greatly appreciate if anybody can tell what is this cable and were it belong.
![]() Join Date: Mar 2003
Looks like a choke cable to me.
Blue 67
I tought so. Thanks for writing back.
1 Wrench / 10 Knuckles
Its not to clear but could it be the tranny kick down cable. Wouldnt the choke cable be on the other side?
1970 GMC Custom Vortec Heads, Edelbrock Performer Intake, Crane 272 Energizer, Hedman Full Length HTC Headers 2006 Dodge Charger SRT8. 1/4 mile 13.3 1973 Z1 900 Kawasaki ( all original) |
That is the choke cable. That is the normal location for the choke cable where it comes through the firewall and the bracket on the cable bolts to the corner screw on the carb bowl cover.
Jim |
Franko72
It could possibly be a cruise control cable.Look on the drivers side inner fender walland see if there is a cruise control setup with the cable attached.
![]() 1972 C20 cheyenne Super 402 BB/400 turbo LWB A/C Tilt, Cruise Control, Saddle tanks, Tach My Home Page Better to burn out than it is to rust |
Throttle cable(is there a extra knob on dash)
56 Chevy Bel-Air 2dr. HT (purchased new) 71 Chevy Cheyenne SWB PU (502HO) 65 GMC short bed step--work in progress and my gofer |
Blue 67
There is no extra knobe on the dash and I don't have cruise control. If that is choke cable, can I just leave it unhooked? or is there any disadvantage to it?
Thanks a lot . |
Please don't take this the wrong way, but what is that horrible monstrosity of carburetor looking thingy atop your engine?
85' CUCV M1009!!! The newest addition! 6.2diesel, Th400, NP208, & only 36k miles! 70' C-10 LWB Fleetside - Looking good these days! ![]() 05' Dodge Neon 88' Winner Escape Sport 1750 - 4.3v6 94' Seadoo SP 84' Honda TRX200, bare nekkid. Just a frame & tires. Always looking for another project or any good deal! ![]() |
Blue 67
I suppose that is a 2 bbl roch carb that previous owner put on this truck which is not working well. I am in process replacing it but since I am new in this field, is taking me some time. I will post the new picture when I am done with it.
I agree with you though!. It looks ugly!. |
![]() Join Date: Nov 2002
oil fill tube
that must be a 307 or a 327 with the oil fill tube and the alt. bracket hooked to the intake. Do the heads have any holes in them for mounting the alt onto the heads?........maybe they are camel back heads?
Blue 67
Engine is 327. I don't know about intake. I know that previous owner changed the carb to 2 bbl. What is camel back intake?
#13 |
cable
Should be choke cable then (pull choke knob on dash and see if end of cable moves).Also check engine code at front of pass. side head on pad in front of it(arrow) (will read like this ##### then 2 or 3 letters--such as JH or CMJ (examples). Engine looks to be a 305CID from the color and type of valve covers. Manifold and carb looks to be 307 type. If you can get these #'s we can tell you what engine it is. Will not hurt to leave cable unhooked .
#14 |
Blue 67
this number is on the block, on the back toward firewall: 3970010.
I didn't see any number infront of the block. There is also a number on the intake: 3877652. |
#15 |
![]() Join Date: Dec 2001
You've got a 4 bolt 350, not a 327.
1942 Master Deluxe 1969 C/10 1985 Blazer CUCV 1987 Jimmy 2004 Tahoe 2005 Silverado 1500 2005 Silverado 3500 |
#16 |
3970010=1968-1979 350 or 327 -2 or 4 bolt main.
3877652= 1965-1967 283 or 327 The number on front of block ( on a small pad right where head meets block-clean it off good) will tell you exact year and size.
#17 |
Do yourself a favor & be sure to get rid of that 2bbl & get a nice 4bbl. Unless gas prices are a really big concern, you will be glad that you did!
#18 |
looks just like the choke cable on my 69. It runs throught the fire wall in what appears to be the same place as yours.
