How much money to have new front,rear,and posi installed???
Never dealt with axle components before but I was wondering how much would it cost for 4.10 gears front/back and an Eaton posi out back too for a Dana 44/12 Bolt? Would have new bearings,seals,gaskets, etc. installed too. How much just for parts and about how much for labor do you think this would run? Thanks!
1972 K-10 Longbox,6" lift w/35's/350/SM465/NP205/3.73 1972 C-10 Longbox,350/350 1998 Pontiac Grand Prix GTP FOR SALE: 1971 K-10 Longbox,350/SM465/NP205 |
if you're going to 4.10s, ditch your 1/2 ton axles. its way more cost effective to swap to a set of 3/4 ton axles than it is to regear 1/2 tons.
I need another Barley Pop
Except for the added cost of changing wheels from 6 lug to 8 lug. I would have ran 3/4 ton axles if I had not already bought my wheels at $250/ea.
67 Short Fleet 4x4 04 Honda CRF450R 89 Toyota 4-Runner 34 Ford 2 door sedan - Long term project ---------------------------------------------- There is a very fine line between "hobby" and "mental illness" ![]() |
#4 | |
3/4 tons typically come with 4.10s standard. hence no need to worry about changing gears. just bolt em in and go. what kind of wheels did you buy?
It's probably gonna be pricey to buy two new gearsets as well as a posi and having both axles rebuilt and then the labor for it all. You could try searching the internet to find out just how expensive new r&p's cost, as well as a posi unit and rebuilt kits for the axles. As for labor, get quotes from a few local shops...be sure to tell them you are supplying everything they need to do the rebuild.
If you already bought six lug rims and don't offroad much, then just stick with 1/2 ton axles, unless you are going with some big-ass tires (35+ inches). Even then, the 1/2 and 3/4 ton front axle are the exact same except the 3/4 ton has 8 lug outers, and the 3/4 ton axles will just add more $$ to your ongoing expense. Just curious, what size tires will you be going with?
1969 GMC K2500 ![]() 1996 Honda Accord 2007 Kawasaki KLR 650 |
Geared for Collision
expect to spend a couple grand to rebuild both of them.
MEMBER OF THE 4 WHEEL DISK BRAKE CLUB 1970 C/K20 3/4 Ton 1996 Collectors Edition Corvette 1977 Corvette Coupe |
It'll probably cost somewhere around 1300 to 1400 for gears and the posi. I can't really say about the labor. It depends if you get Joe Smo to do it or if you take it to a shop.
![]() Join Date: Mar 2002
I just changed the gear ratio (4:56 to 3:73) and added a posi, plus all new bearings. Parts were about $600 for the rear only. I wanted to make sure the ratio was to my liking before doing the front. So, I think the price will range from $1500 to $2000 for both axles including labor.
1968 GMC 305 V6 3/4 4x4 Stepside 06 Corvette Daily Driver Dallas TX |
Certified Chevy Man
I had 3.07's and rear Detroit in my suburban(Dana 44/12 bolt). I re-geared myself to 4.10's with a front locker(Detroit E-Z locker) too with all new parts for about $900
68 Chevy CST (327,TH400) 3/5 drop lots of fun stuff 71 Suburban 4x4 (350,TH350) 7" lift 37's, D44/14 bolt and other sorts of goodies, lockers front and rear, flexes 40", 895 RTI score Check out my web site!!! http://www.geocities.com/cst68chevy/ |
It's going to be expensive, but well worth it from a drivibility standpoint. This is especially true with tires over 33".
Front gears............................175 Rear gears.............................190 Eaton Posi.............................420 Bearing and shim kit for rear.......80 Pinion seal (Front) & Lube..........20 Parts total (approx)...............885-900 Labor........(100-125 R)(125-150 F) So it looks like 1200 bucks should get you pretty close. You may get a better deal for doing it all at once, depending upon who does the work. |
I have a 1 ton Eaton with a Detroit Locker, not sure what the gearing is (4.10, 4.56, 0r 5.13). But it is a beast of and axel and would be cheaper than re-gearing your old one. If you want it let me know, but shipping to ND might be a little pricey.
#13 |
dosen't really cost as much as one thinks to ship axles by frieight--shipped a 1 ton dana with posi arb lockers with disc brakes and all for about 300 bucks--and that was from calif to maine....by yellow frieght
hope this helps----as for me if i was to do it over again--i would go dana's front and rear-only with 6 lugs on them....much more choices in rims that way....the shop near me wants 1400-2000-to do what you need done....but only-650-to do the work if i install and uninstall.... good luck aabear john |
#14 |
![]() Join Date: Feb 2001
A few years ago I picked up some 3/4 tons that the guy had gone through and added disk brakes for under 500..........they are 4.10's.
