Old 05-30-2004, 03:21 PM   #1
my new 72
faster, faster, faster
my new 72's Avatar
Question Blazer tank straps???
What is the deal with the new blazer tank kit straps? They do not seem to be long enough to go from left to right between the frame rails. I am putting the 72 back together for my dad and he got a new poly tank from Outback truck parts in Spring, and the straps are too short. It is going in a LWB, so there is no crossmember in front of where the tank mounts. What is the deal here? Any of you vendors know why the straps are shorter than they used to be? Or are the straps the same length and I am just not seeing things clearly? Thanks for the help in advance.
I'm going to Law School, wanna debate? It's good practice.
my new 72 is offline   Reply With Quote
Old 05-30-2004, 09:20 PM   #2
my new 72
my new 72's Avatar
Anyone have a clue here???
Old 05-30-2004, 10:06 PM   #3
Mudder
Mudder's Avatar
The only factory straps I have seen went from front to back. I dont have a clue otherwise.....
Mudder is offline   Reply With Quote
Old 05-30-2004, 10:24 PM   #4
jorgensensc
jorgensensc's Avatar
The ones that go on the aftermarket tank are side to side. They seem really short, but after you tightn them up a lot of slack really comes out of them ithought they were too short also when I did mine, but they turned out fine. If they had been longer they might not have tightened up all the way.
Shawn
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
Old 05-30-2004, 11:17 PM   #5
my new 72
my new 72's Avatar
Good deal Shawn. I was hopeing that the straps would work from side to sode like I did when I had the truck. Next week we should be firing it up for the first time. I never thought it would be this hard to talk someone into using Hooker Comp headers, but he seems to be dead set on manifolds. Go figure, he just won't listen. Thanks again Shawn.
